ngfilla94
Nathan
St. Peters, MO
2015 4Runner Trail
The Pro matte alloy wheels are a different offset from what the other trims run. It's like 1" difference in offset which will result in the tires sticking way past the fenders on a non-Pro/Trailhunter. The 5th gen Pro that was more or less the exact same fitment.
Now, there is an 18" TRD accessory wheel that is available on TRD Off Road per the configurator. It is the same 18" TRD matte black wheel available on the Tacoma.
Yeah, those are the wheels I'm referencing. I saw they were only available as an option on the OR. I guess the issue is tire size, since there are some various sizes now vs 5th gen. I'm looking at a TRD Sport Premium (20" Wheels) and was hoping to get a more aggressive wheel and tire combo without having to go aftermarket immediately.
Administrator
Administrator
Staff member
Highlander
I don’t see the sway bar disconnect mechanism listed anywhere. Standard for the TRD OR would be a nice surprise.
Here's confirmation from the official 2025 4Runner Toyota website that SDM (Stabilizer Disconnect Mechanism) / Electronic Sway Bar Disconnect is standard on the TRD Pro and Trailhunter. 👍
2025 Toyota 4runner Trims Comparison Chart: Optional vs. Standard features, equipment, options for 2025 4Runner electronic sway bar disconnect 2025 4runner trd pro trailhunter
qtb007
Quentin
Hurricane, WV
23 GR Corolla, 23 4Runner Pro
Typically the accessory wheels get the tires that ship with the vehicle. They take the tire off the OEM wheel and remount it to the accessory wheel. That's why the 18" accessory wheel isn't listed as an option on the SR5 (17"), Limited (20"), Platinum (20"), or Sport (20"). That wheel isn't technically available on the Tacoma TRD Off Road (17"), either, for the same reason. It is available on the Tacoma TRD Sport. What's wild, to me, is that they have a 17" wheel and an 18" wheel that is more or less the same style between the Tacoma and 4Runner TRD OR trims.
IMO, just buy the 18" wheels from the parts counter and mount the tire that you want on it. Sell the 20" wheels and tires on facebook marketplace. You'll get surprisingly decent money if you do it before you put many miles on them.
qtb007
Quentin
Hurricane, WV
But what about TRD Off Road? SDM is available on Tacoma TRD Off Road.
qtb007
Quentin
Hurricane, WV
SDM sway bar disconnect isn't available for TRD Off-Road or any other trims (besides being standard on 4Runner TRD Pro and Trailhunter).
electronic sway bar disconnect 2025 4runner trd pro trailhunter trd off-road.jpg
Oof. That sucks. Wild that they take a feature available on like 50% of the Tacoma volume and limit it to like 8% of 4Runner volume.
I had KDSS on my ‘16 4Runner and missed the thick sway bars when I went to a ‘23 Pro (which admittedly rode a ton better than the ‘16 even though the handling was lacking). The SDM seems to make a huge difference on the Tacoma regarding articulation. So, for the 4Runner Off Road, we either get sloppy handling and good articulation or tight handling and give up articulation depending on the spring and sway bar combo selected. Another advantage of a mid trim Land Cruiser.
AZTrail
2011 4Runner Trail
Could the lack of the SDM option for the OR and ORP trims be due to a parts shortage? What are the chances that the 2026 4Runner will have a SDM option?
kekecarioca
_CAC_
1999 4runner SR5 4x4 Manual
Does anyone know If SDM (sway bar disconect) is standard in TRD OR? if not will it be optional without Premium package.
I might be blind an missed it...
Administrator
Administrator
Staff member
Highlander
Sway bar disconnect (SDM) is not standard nor available as option on 2025 TRD Off-Road, including Premium Package. See --
2025 Toyota 4runner Trims Comparison Chart: Optional vs. Standard features, equipment, options for 2025 4Runner sway bar disconnect sdm stabilizer disconnect mechanism 2025 4Runner TRD Off-Road & Premium
kekecarioca
_CAC_
:cry::cry::cry: I totally missed the Specs on the main 4runner page. thanks!
sway bar disconnect sdm stabilizer disconnect mechanism 2025 4Runner TRD Off-Road & Premium.jpg
andim
Boston
2015 Cherokee Trailhawk
There are a few weird things in the list. The Trailhunter is listed with standard "Frame-mounted stelrockrails" but on the Toyota website it looks like a $990 option. What is the situation there?
kzrman
Maine
2018 4Runner TRD off-road
There are a view weird thing in the list. The Trailhunter is listed with standard "Frame-mounted stelrockrails" but on the Toyota website it looks like a $990 option. What is the situation there?
I noticed that as well.
I would guess that it's a oversight by Toyota.
andim
Boston
Didn't see that, thanks. Too bad neither of those trims are what I want. TRD Off_Road w/3rd row seats would make me happy.
When the TRD off road is out and people start modifying it we will see if the mounting points for the third row are present in the TRD off road. I assume they are there as even the cupholders are there. Then it will be only a short time until you can buy the third row seat and seatbelts separately and install them. However, it may be a regulatory issue to do this so I wouldn't expect aftermarket kits to do that.
