BLACK 2025+ 4Runner 6th Gen Thread
KTRAN
Kevin
Bay Area CA
4R
Black 4Runner looks so good built up...
Mods on this 2025 4Runner TRD Sport 6th Gen Build by Westcott:
Air dam removed
17" Method 703 wheels +35 offset
Preload collar lift with 0.5" top shim (lifts height 2.25" inches)
- Fender liner moved forward for extra clearance (to avoid tire rub at full steering lock)
- Removed carpet covered piece at back of front fender (to avoid tire rub at full steering lock)
Toyo Open Country A/T3 tires (35x12.50R17)
Rock sliders
Low-profile roof rack
MOLLE panel system with integrated bottle opener
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Black 2025 4Runner TRD Sport Build (Westcott) 35's, +35 offset wheels, preload collar lift, ro
Jack
Jack
SLC, UT
FJ
OEM accessory Trailhunter ARB 3/4 Length Roof Rack and TRD 18" Wheels on a Black 2025 4Runner 6th gen.
Falken Wildpeak A/T3W tires.
TRD 18" Wheels Specs:
18x8" cast aluminum wheel
18x8.5 139.7 6 lug
+45 mm offset
$1,325 MSRP ($925 dealer cost)
PART# PT946-35240-2F (or PTR56-35242-F1)
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Trailhunter ARB 3:4 Length Roof Rack + TRD 18%22 Wheels (Black) on TRD Off-Road TRDOR 2
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Trailhunter ARB 3:4 Length Roof Rack + TRD 18%22 Wheels (Black) on TRD Off-Road TRDOR 1
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Trailhunter ARB 3:4 Length Roof Rack + TRD 18%22 Wheels (Black) on TRD Off-Road TRDOR 3
Bernie
2018 Mercedes AMG GTc
The black on Trailhunter looks way better than Everest; it even camouflages that obnoxious snorkel! Either one will be hard to keep clean.
olefriend
TX
Supra A90
More looks at a black 2025 4Runner TRD Off-Road with the TRD 18" Wheels and ARB Roof Rack.
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread 2025 4Runner TRD Off-Road with the TRD 18%22 Wheels and ARB Roof Rack 2
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread 2025 4Runner TRD Off-Road with the TRD 18%22 Wheels and ARB Roof Rack 1
Administrator
Administrator
Staff member
Jay
Black TRD Sport 2025 4Runner 6th gen on:
Elevate Level Kit
17" Method MR703 Wheels
285/75R17 BFG KO3
Chrome Splined Lug Nuts
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Black TRD Sport 2025 4Runner on Elevate Level Kit, 17%22 Method Wheels, 285:75R17 BFG KO3 tire
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Rough Country's Black TRD Off-Road build with:
Rough Country 3.5" in lift kit
Rough Country M/T Mud Terrain Tires (285/65/18)
18" Rough Country Series 78 RC Wheels (0 offset)
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 6
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 1
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 2
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 3
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 4
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 5
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 10
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 9
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 8
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 7
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread 2025_4runner_3.5in_n3_lift_-_76931
Official Description
Rough Country's 3.5-Inch Lift Kit for the sixth-generation Toyota 4Runner TRD Offroad is engineered for adventure - whether you're conquering rocky trails, powering through muddy backwoods, or making a bold statement on the road. Elevate your ride with superior suspension, enhanced durability, and a perfectly leveled stance built for anything the trail throws your way.
Massive Ground Clearance: Gain 3.5 inches of added height to dominate rough terrain with ease. No more getting hung up on rocks or ruts - just pure off-road performance.
Perfectly Balanced Stance: Eliminates the factory rake, leveling the front with the rear for an aggressive, commanding look.
Premium Suspension Upgrades: Includes high-quality upper control arms designed to maintain optimal ball joint angles, reducing wear and tear for long-lasting performance.
Enhanced Stability & Handling: A rear track bar bracket keeps the rear axle properly centered, improving control on and off the road.
Durable & Dependable: Control arms feature rubber bushings for increased longevity and smoother suspension articulation.
Hassle-Free Installation: Designed for an easy bolt-on setup - no cutting, no drilling, just a quick and straightforward upgrade.
Get ready to push your Toyota 4Runner to new heights with Rough Country's 3.5-Inch Lift Kit - because adventure doesn't wait, and neither should you!
Fitment Notes
  • Fits TRD Offroad models ONLY.
  • Does NOT fit models equipped with Adaptive Variable Suspension (AVS).
  • Does NOT fit Trailhunter models. (Models equipped with OLD Man EMU suspension.)
  • Does NOT fit TRD PRO models. (Models equipped with TRD-tuned FOX suspension.)
https://www.roughcountry.com/product/toyota-suspension-lift-kit-76931
Old Spice
Bay Area
X3 currently
Bronze badge overlays looking good on black TRD Off-Road 2025 4runner 6th gen.
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Bronze badge overlays on black 2025 4runner off-road  3
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Bronze badge overlays on black 2025 4runner off-road  2
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread Bronze badge overlays on black 2025 4runner off-road  1
4running
TX
2020 4Runner SR5
Black TRD Sport 2025 4Runner build with premium tail lights which looks so good on black. Mods list -
3" spacer lift
17" Icon Alloys (Hulse)
35" tires (35x12.50R17) - Toyo Open Country A/T III (AT3)
OEM Premium Tail Lights
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread n-35s-open-country-at3-35x12-50r17-premium-tai-
TN Vols
TN
'19 Toyota Tacoma SR5
Black 4runner Trailhunter
2025 Toyota 4runner BLACK 2025+ 4Runner 6th Gen Thread black trailhunter 4runner
