Administrator
Administrator
Staff member
Highlander
Link to full specs PDF ➡ https://www.4runner6g.com/forum/att...f.5259/?hash=3c495b739daf7cd66db8b99723081ab1
Link to wallpapers ➡ https://www.4runner6g.com/forum/threads/2025-4runner-wallpaper-photos-specs-🔥-trailhunter-trd-pro-off-road-limited-trims.1283/
Official 2025+ 4Runner 6th Gen Specs
Trim Levels / Models
(click on each for specs, features, options, accessories):
  1. SR5 (i-Force)
  2. TRD Sport (i-Force)
  3. TRD Sport Premium (i- Force)
  4. TRD Off-Road (i-Force / i-Force Max Hybrid)
  5. TRD Off-Road Premium (i-Force / i-Force Max Hybrid)
  6. Limited (i-Force / i-Force Max Hybrid)
  7. Platinum (i-Force Max Hybrid)
  8. TRD Pro (i-Force Max Hybrid)
  9. Trailhunter (i-Force Max Hybrid)
Colors:
Engines
  • i-FORCE (Gas Option)
    • Type: 2.4L 4-cylinder Turbocharged, DOHC
    • Fuel System: D-4ST Fuel Injection
    • Displacement: 2,393 cc
    • Horsepower: 278 hp @ 6000 rpm
    • Torque: 317 lb-ft @ 1700 rpm
    • Fuel Economy:
      • 2WD (SR5, Sport, Sport Premium): 20 MPG city / 26 MPG highway / 22 MPG combined
      • 4WD (SR5, Sport, Limited, etc.): 19 MPG city / 25 MPG highway / 21 MPG combined
    • Engine Oil Capacity: 5.9 quarts (with filter)
    • Fuel Tank Capacity / Gas Tank Capacity: 19 gallons
    • Recommended Fuel Type: Regular Fuel / Gas
  • i-FORCE MAX (Hybrid Option)
    • Type: 2.4L 4-cylinder Hybrid Turbocharged, DOHC
    • Horsepower: 326 hp @ 6000 rpm
    • Torque: 465 lb-ft @ 1700 rpm
    • Fuel Economy:
      • 4WD (Off-Road, Limited, TRD Pro, Trailhunter): 23 MPG city / 24 MPG highway / 23 MPG combined
Drivetrain / Transmission
  • Drivetrains:
    • 4x2 (Rear-wheel drive RWD)
    • 4x4 (Part-time or Full-time four-wheel drive 4WD)
  • Transmission Type:
    • 8-speed Automatic Transmission with following gear ratios:
      • 1st gear: 4.41
      • 2nd gear: 2.80
      • 3rd gear: 1.95
      • 4th gear: 1.51
      • 5th gear: 1.27
      • 6th gear: 1.00
      • 7th gear: 0.79
      • 8th gear: 0.65
      • Reverse: 3.64
  • Transfer Case (4x4 models):
    • High/low ratio of 1.00:1 / 2.57:1
  • Final Drive Ratio:
    • 3.583
Vehicle Weight
  • Curb Weight (lbs):
    • Gas Engine (i-Force)
      • 2WD SR5: 4,455 lbs
      • 2WD TRD Sport: 4,610 lbs
      • 2WD Limited: 4,730 lbs
      • 4WD SR5: 4,685 lbs
      • 4WD TRD Sport: 4,850 lbs
      • 4WD TRD Off-Road: 4,850 lbs
      • 4WD Limited: 4,970 lbs
    • Hybrid Engine (i-Force Max)
      • Hybrid TRD Off-Road: 5,225 lbs
      • Hybrid Limited: 5,370 lbs
      • Hybrid Platinum: 5,390 lbs
      • Hybrid TRD Pro: 5,455 lbs
      • Hybrid Trailhunter: 5,500 lbs
  • Gross Vehicle Weight Rating (GVWR) (lbs):
      • 2WD SR5: 6,005 lbs
      • 2WD TRD Sport: 6,020 lbs
      • 2WD Limited: 6,130 lbs
      • 4WD SR5: 6,075 lbs
      • 4WD TRD Sport: 6,395 lbs
      • 4WD Off-Road: 6,240 lbs
      • 4WD Limited: 6,395 lbs
      • Hybrid TRD Off-Road: 6,505 lbs
      • Hybrid Limited: 6,505 lbs
      • Hybrid Platinum: 6,505 lbs
      • Hybrid TRD Pro: 6,505 lbs
      • Hybrid Trailhunter: 6,505 lbs
Exterior Dimensions
  • Wheelbase: 112.2 inches
  • Length: 194.9 inches
  • Width: 77.9 inches (79.9 inches for TRD Pro / Trailhunter)
  • Height:
    • SR5: 72.6 inches
    • Sport, Limited, Platinum: 73.1 inches
    • Off-Road / Off-Road Premium: 73.6 inches
    • TRD Pro / Trailhunter: 74 inches (75.5 in w/ roof rack)
Interior Dimensions
  • Seating Capacity: 5 (7 seats available on i-FORCE SR5 and Limited trims)
  • Interior Space:
    • Shoulder Room (Front/Rear): 58.0 in / 57.8 in
    • Hip Room (Front/Rear): 55.2 in / 56.1 in
    • Headroom (Front/Rear): TBA
    • Legaroom (Front/Rear): TBA
  • Cargo Capacity: N/A (varies by configuration)
Wheels, Tires, Bolt Pattern, Lug Nut Size, Hub Bore:
17" inch dark gray metallic alloy wheels​
TRD Sport (Premium)
20" inch machine finished alloy wheels​
31.5" Yokohama Geolandar A/T G015 Tires (265/55R20)​
TRD Off-Road (Premium)
18" inch machine finished alloy wheels​
32.6" Michelin All-Terrain tires (265/70R18)​
31.5" Dunlop Grandtrek AT20 tires (265/55R20)​
20" inch black alloy wheels​
18" inch flat bronze finished alloy wheels​
33" inch Toyo Open Country A/T III All-Terrain tires (265/70R18)​
18" inch flat black finished alloy wheels​
33" Inch Toyo Open Country A/T III All-Terrain tires (265/70R18)​
Bolt Pattern: 6-139.7​
Lug Nut Size: 14x1.5​
Hub Bore: 95.1​
Suspension
  • Front Suspension: Independent double-wishbone with stabilizer bar and twin-tube shock absorbers
  • Rear Suspension: Multi-link with coil springs and outboard-mounted twin-tube shock absorbers
  • Steering:
    • Electronic Power Steering (EPS)
    • 3.25 turns lock-to-lock
    • Turning Radius: 19.7 ft
Ground Clearance, Approach Angle, Departure Angle, Breakover Angle
Off-Road
TRD Pro / Trailhutner
Approach Angle
18 degrees​
18 degrees​
19 degrees​
33 degrees​
Departure Angle
22 degrees​
22 degrees​
24 degrees​
24 degrees​
Breakover Angle
23 degrees​
24 degrees​
24 degrees​
24 degrees​
Ground Clearance
8.1 inches​
8.8 inches​
9.1 inches​
10.1 inches​
Safety Features
  • Toyota Safety Sense 3.0 is standard on all 2025 models and includes:
    • Pre-Collision System with Pedestrian Detection
    • Lane Departure Alert with Steering Assist
    • Full-Speed Range Dynamic Radar Cruise Control
    • Lane Tracing Assist
    • Road Sign Assist
    • Automatic High Beams
    • Proactive Driving Assist
Off-Road Tech / Features
  • Front stabilizer bar disconnect
  • 2wd, part-time 4wd, or full time 4wd
  • Locking rear diff standard on TRD Off-Road, TRD Pro or TrailHunter.
  • MTS (Multi-Terrain Select)
  • Crawl Control
  • Approach Angle: 32 Degrees
  • Departure Angle: 24 Degrees
  • TRD Pro Light Bar
  • Rigid Fog Lights
Production
  • December 2024 start of production for non-hybrid models
  • February 2025 start of production for hybrid models
Pricing
  • See all MSRP base prices & options pricing at: 4runner6g.com/forum/threads/2025-4runner-price-release-msrp-options-pricing-for-all-trim-levels-gas-hybrid-models-6th-gen.1952/
2025 Trim Levels Compared: features, equipment, options
Text searchable PDF version of the chart (PDF download): 2025 toyota 4runner trims comparison - features options exterior chart.pdf
Connect
JD
Tx
2013 Honda Accord, 2023 Maverick XLT Hybrid
I was not expecting to like this that much... I don't generally think of a 4runner as an option for me since I value MPG. I was given a 5G several years ago as a rental and it was fine but nothing stood out to me. That all being said I am really liking this one so far. ;)
