Dongar
Kevin
Norcal
2024 Tacoma TRD OR
Hello 6G Community :)
We’re Dongar Technologies — longtime Toyota truck guys, dashcam enthusiasts, and now proud sponsors of 4Runner6G.
We invented the (often-copied) plug-and-play dashcam power adapters that connect directly to your vehicle’s rearview mirror harness. That means no fuse taps, no wire splicing, and a clean, factory-style install in minutes.
There’s not enough clearance to put the plastic covers back on over a fuse holder (aka ‘add-a-circuit’ or ‘fuse taps’). As such, you must modify the plastic cover, or simply keep them off. This is a huge bummer for anybody attempting to use a fuse-tap style hardwire kit or dashcam!!
2025 4runner 6th gen Dongar Technologies - 6th Gen Dashcam Power Options Now Live! 1745459951602-mh
2025 4runner 6th gen Dongar Technologies - 6th Gen Dashcam Power Options Now Live! 1745459971999-iq
We’ve just confirmed compatibility with the 6G 4Runner and now offer 4 products that cover all trim levels. If you’ve got a camera, radar, or other tech behind your mirror, odds are we have something for you.
? Supported 6G 4Runner power:
  • via Auto-dimming mirror 10-pin plug
  • via domelight cavity harness (meant for OEM dashcam!) 5-pin plug
  • via Lane Trace System 16-pin plug
We’ll be hanging out in this sponsor area to answer questions, collect feedback, and support installs — and yes, we’ll be doing a few giveaways soon ? Stay tuned for forum-exclusive discounts!
Check us out at dongar.tech or drop a comment here with your setup and we’ll help match you with the right adapter.
Excited to be part of the 6G launch and community ?
— Kevin @ Dongar
Find us:
https://dongar.tech
https://amazon.com/dongar
6G 4Runner Dongar Quick Product Reference Guide
ProductSKUOperating ModesCompatibilityOutputNotes
Dongar PRO Toyota/Lexus Cable PackPMA-01Ignition-on
Always-on w/ low voltage protection and timer
All trim modelsTrue 5V / 9V / 12V
USB-C
Comes with both 10-pin Type B rear-view mirror harness and 5-pin Type A roof cavity harnessDongar PRO
Dongar 10-pin Type BDCA-10BIgnition-onOnly trim levels equipped with OEM auto-dimming mirror5V USB-A
(5/9/12V USB-C coming soon!)
Uses connector going to auto-dimming mirror10-pin Type B
Dongar 5-pin Type ADCA-5AIgnition-onAll trim models5V USB-A
Recommended. Uses same connector as OEM dashcam5-pin Type A
Dongar 16-pin Type TDCA16TIgnition-onAll trim models5/9/12V USB-CPlugs into TSS 3.0 Lane Trace Assist system
donayre21
Subaru
what are the difference between 1 and 2? I need it for my 2025 4runner
2025 4runner 6th gen Dongar Technologies - 6th Gen Dashcam Power Options Now Live! Screenshot_20250423_220826_Amazon Shopping
Dongar
Dongar
Kevin
Norcal
2024 Tacoma TRD OR
@donayre21 PMA-02 is for Mazda, sorry for the confusion. PS, the units available at our webshop are guaranteed to be the latest versions (with new instruction manuals and small improvements) Amazon has some old stock.
donayre21
Subaru
Why didn't they get removed from Amazon. You are selling them in there right?
Dongar
Dongar
Kevin
Norcal
2024 Tacoma TRD OR
@donayre21, there's nothing wrong with them, we just add improvements each time we start a new production and they haven't received the latest build yet. The improvements are small but meaningful, like the adhesive tape on the base is better.
Vincenzo
Southeast
Is it imperative to use the Pro module? Have a Garmin47 and I’m not concerned with 24 hour recording. TRD Sport Premium with auto dim. 10 pin harness will suffice?
Rellims
Sean
ORP - Underground
How does the always on feature work, doesn't the rear view shut off when the 4runner is not running?
Dongar
Dongar
Kevin
Norcal
2024 Tacoma TRD OR
@Vincenzo, yes the 10-pin harness would suffice, but the connector isn't standard on all trim levels. I would recommend using the 5-pin harness in the domelight which is in 100% in all trims. Don't have to use the PRO module, but there's an ignition-only mode on it so you have the flexibility just in case. Our other 5-pin and 10-pin products are gaining USB-C in the next month, so I'd wait for one of those or just get the PRO.
@Rellims there's always-on power going to the mirror actually, probably for the homelink buttons.
Vincenzo
Southeast
When pulling down the dome light housing, be warned. You will have to get your fingers in deep. There is a separate trim piece around the circumference of the housing that snaps off pretty easily. One of the tabs broke off. It seems fine. The video makes it look easier than it is.
