Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen
Pelo18
Vancouver
2006 Toyota RAV4 Limited V6/ 2025 TRD Pro 4Runner
Magnaflow just released exhaust for 4Runner TRD Pro. Works with both hybrid and non-hybrid vehicles.
https://www.magnaflow.com/products/...nd-series-cat-back-performance-exhaust-system
MagnaFlow 2025 Toyota 4Runner Overland Series Cat-Back Performance Exhaust System
The MagnaFlow Toyota 4Runner Overland Series Cat-Back Performance Exhaust System #19657 is engineered for off-road function and built to explore further. This Toyota 4Runner exhaust system is designed for the 2025 Toyota 4Runner equipped with the L4 2.4L engine. The high clearance exhaust design of this kit is intended to keep your truck clear of any challenging terrain or obstacles you may come across. #19657 3” diameter mandrel bent main piping passes through an all-new specifically tuned performance oval and round mufflers with No Drone Technology (NDT) before exiting in a high-clearance single driver side rear exit style. MagnaFlow NDT utilizes passive quarter-wave noise cancellation to minimize the unwanted droning noises that can otherwise occur at highway cruising speeds. Exhaust kit #19657 utilizes a direct-fit, easy to install design that replaces your OEM exhaust system from the catalytic converter on back. This Toyota 4Runner cat-back performance exhaust system is made of durable, corrosion resistant stainless steel and produced using advanced CNC precision robotic manufacturing techniques, all backed by MagnaFlow’s limited lifetime warranty.
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen 1744982779851-m0
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen Magnaflow Exhaust Aftermarket 2025 4Runner 6th Gen Hybrid and Non-Hybrid Gas Engine 2.41
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen Magnaflow Exhaust Aftermarket 2025 4Runner 6th Gen Hybrid and Non-Hybrid Gas Engine 2.42
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen Magnaflow Exhaust Aftermarket 2025 4Runner 6th Gen Hybrid and Non-Hybrid Gas Engine 2.46
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen Magnaflow Exhaust Aftermarket 2025 4Runner 6th Gen Hybrid and Non-Hybrid Gas Engine 2.43
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen Magnaflow Exhaust Aftermarket 2025 4Runner 6th Gen Hybrid and Non-Hybrid Gas Engine 2.44
2025 4runner 6th gen Magnaflow Aftermarket Exhaust (Cat-Back) for Hybrid 2025+ 4Runner 6th Gen Magnaflow Exhaust Aftermarket 2025 4Runner 6th Gen Hybrid and Non-Hybrid Gas Engine 2.45
CMill4Runner
Craig
CO
Did you see a dyno anywhere, I can't find it on their site?
EarthPIG_0311
The 90660
'25 4Runner Limited i-Force Max, '20 Civic Si
Do we know if this fits all trims with the Max engine? I ask for 2 reasons.
1. If I chose my trim, Limited, it only gives me the gas option for engine.
2. IIRC, in watching a review vid on YT, it was mentioned that both the TRD Pro & Trailhunter's exhaust pipes were laid/routed with more clearance in mind since those trims come with off-roading in mind from the factory. This leads me to believe that a non off-road oriented trim like mine, may have different exhaust lay out.
TrdProGirl84
I might be interested. lol. I has a Magnaflow Cat-back exhaust on my Camry XSE before I bought my Pro 4Runner. This might be happening soon.
