Sherpa or Westcott Lo-Pro roof rack??
Ericd6972
Eric
Delaware
2025 TRD ORP
Has anyone Installed the Westcott low pro roof rack? Also wondering if it will work with a sunroof. Torn between it and the Sherpa. Thanks
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
This isn't mine but here's installed pics of the Sherpa roof rack on the 6th gen.
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? sherpa roof rack 2025 4runner 6th gen 5
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? sherpa roof rack 2025 4runner 6th gen 4
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? sherpa roof rack 2025 4runner 6th gen 1
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? sherpa roof rack 2025 4runner 6th gen 3
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? sherpa roof rack 2025 4runner 6th gen 2
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Thanks, I've seen the Sherpa on a few and have talked to a few that have installed it. Mainly looking for more info on the Westcott and if it works with sunroof. Also like the look of the low pro and its $500 cheaper.
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Awesome! Thanks for the video!
DocASim
Al
Las Vegas
2014 Mercedes-Benz C63 AMG Edition 507
Ericd6972,
I specifically spoke to the people at Westcott designs regarding the roof rack and the moonroof. They told me that it fits fine. I have it on order.
TomSr
Tom
New England
2025 SR5, 2025 Defender, 2020 Gladiator Rubicon, 2016 Range Rover
Just installed Westcott Lo-Pro rack, molle and recovery board mount. Could not be happier with the quality and fit. Had my detailer/modifier install since was having other work done. He agreed on the fit and quality. Would not hesitate to use Westcott. Super tight/low profile fit.
Video and Photos:
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? 76722314527__4BA827D5-F970-4C86-AC18-94CB90510F3E
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? 76722315923__50ED52B6-EEAA-48E9-827B-E0AB54986B3C
2025 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? 76722315207__5621E6DE-FE03-4066-B363-EC3609611F10
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Just installed Westcott lo-pro rack, molle and recovery board mount. Could not be happier with the quality and fit. Had my detailer/modifier install since was having other work done. He agreed on the fit and quality. Would not hesitate to use Westcott. Super tight/low profile fit. I tried to post video but it uploading upside down for some reason. I can take some pics in the morning and post
I believe I saw the video when you posted it. It came through just fine. I appreciate it.
TomSr
Tom
New England
Great. I just edited it with a couple of pics too. Also, I spoke to the guys at Westcott a couple of times and were very helpful.
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
that looks awesome! I know with the Prinsu rack you need to trim weather stripping on roof and use rtv silicone for install, any idea if it's the same with the Westcott?
TomSr
Tom
New England
Yes. I suspect install process is pretty much the same for both. Remove rails. Use same bolt holes (and silicone) to mount rack and then with Westcott the front uses a bracket with double sided tape. That part was only element that a little tricky but I think because the fit is so low profile and really exact. They have very detailed videos on their site for the entire install process. I built it in about 30 mins. And probably took my guys an about two hours to mount mostly due getting that front part to work exactly. They put a strip of PDX wrap down but probably not necessary. I think a super good wax application fine.
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Can you post a link to install video? Cant seem to find it
TomSr
Tom
New England
Yeah. Not that easy to find. Their youtube channel has some interesting and helpful videos. I asked them to send me one. They send two. I thought this one was best.
Ericd6972
Ericd6972
Eric
Delaware
2025 TRD ORP
Thanks!
4Runner-Dan
Dan
Boston
I looked them over and ordered the Sherpa. Here's why:
- clearance between crossbars and roof appears to be better for Sherpa rack
- Very beefy 0.25-inch side plates. Important to support the cantilevered forward section of the rack.
- No need to cut the roof molding to install
- Three large cutouts in side plates will allow strap buckles to pass through.
