UNDERGROUND Photos 4Runner 6th Gen (2025+)
Cory39744
Cory
Virginia, USA
2025 4Runner TRD Pro in Underground with Cockpit Red Interior
-295/70R18 Nitto Recon Grapplers
-Peak Suspension 1in top shim and 1in rear spacer
-Ceramic Coating
-Screen Protech film for Infotainment
Starting suspension measurements for the Pro was:
Front - 21 3/4
Rear - 22 5/8
After small lift:
Front - 22 3/4
Rear - 23 1/2
I am in love with this truck. I still have my 21 TRD Pro but this one is next level.
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2058
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2062
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2059
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2060
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2061
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2063
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2064
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2065
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2066
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2067
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
2025 4Runner TRD Off-Road Premium ORP on:
Work Meister M1HC 18Ă—9 +25 offset in Hyper Gunmetal with diamond cut lip
Yokohama G003 295/70/18 tires
Ready Lift 2.5 Lift
Seibon Carbon Hood TS Style
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) TRD Off-Road Premium ORP on Work Meister 18x9 +25 offset aftermarket wheel, Yokohama G003 295:
Henry
Henry
CT
Falken Wildpeak AT4W tires 275/65/18
Method 302 Wheels in Bronze +18 offset
No lift (stock suspension)
No rubbing
This 4Runner belongs to Leo R.
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) ls-18-offset-and-wildpeak-at4w-275-65-18-tires-
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) ls-18-offset-and-wildpeak-at4w-275-65-18-tires-jpg
Jadon.lm
Kia Rio 2012
I just got a 285/70/R17 set of tires, do you think these would fit without lifting and with a similar wheel spec?
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
Underground SR5 on
âś… Old Man Emu MT64 3" inch suspension kit
âś… Nitto Ridge Grapplers 35x11.50R17
âś… Method 318 Wheels 17x8 +25 offset
âś… ARB Roof Rack
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) lift-kit-nitto-ridge-grapplers-35x11-50r17-met-
Nostik21
2018 Jeep Wrangler Rubicon JLU
Mickey Thompson Baja Boss A/T
285/65/18 (33.2" Dia)
Wanted to try the wider and slightly bigger diameter Mickey's on the stock suspension and upgraded TRD 18" Wheels (+45 offset) to report if there will be any rubbing for this tire size. They fit great with no rubbing.
I'd like to maybe put some +35 or +25 offset wheels on it but I'm not in a huge hurry as they look pretty good. I think some +35 - +20 wheels will give a good poke but will rub a tiny bit without a leveling kit, lift kit, or at least pushing the front wheel well felt forward and removing the rear cover and bracket. Any of these options should do to eliminate rubbing should you choose a wheel with more poke and these wider tires.
Love those Mickey Thompson, have them in 37s on my jeep. Might have to wait a bit to get them on the 4Runner when it’s delivered.
Great tires though
lb1606
FL
No rubbing
Are you still running this setup with no lift (stock suspension)? Never had any rubbing at all especially on full turn? Do you have hub centric rings on them or just running extended lug nuts? Thanks in advance.
Keroppi
Hawaii
Underground 2025 4Runner TRD Off-Road Premium 6th gen build on:
ReadyLift 1.5 Front Lift Kit
Volks TE37xt 17x8.5 +15 Offset (Diamond Black Finish)
Mickey Thompson Baja Boss AT 285/70R17 Tires
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) fset-wheels-285-70-17-baja-boss-at-2025-4runne-
Walkaround video
olefriend
TX
Underground 2025 4Runner TRD Sport build by 8RunnerOffRoad
  • Westcott Designs Leveling Kit (6th Gen 4Runner)
  • Toyo Open Country R/T Trail Tires – 33x12.5R17LT (285/70R17 equivalent)
  • Method 305 NV Double Black Wheels – 17x8.5 +25 Offset (x4)
  • Method Race Lugs
  • OEM TPMS Sensors
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) 5r17lt-open-country-r-t-method-305-nv-25-offse-
wirenut386
Adam
New Smyrna Beach, FL
Underground ORP with:
  • Westcott Modular Roof Rack
    • Cut Out for Ten (10) 4" Round Lights
    • Floor Inserts
  • Westcott Molle Panels x 2
  • Westcott Ditch Light Brackets
  • RC 3.5" Lift Kit
  • Bulletpoint Mounting Solutions RubiGrid w/various holders
  • Yaesu FTM-510DR w/Comet 2X4SR.
Next wheels/tires but still undecided, then ladder.
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2579_cut.JPEG
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2601
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2549.JPEG
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2568.JPEG
Claw832
Houston
2025 4runner
Stock suspension
RRW RS7-H MonoForged +25 wheel
Toyo Open Country A/T 285/75/17
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2307
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2310
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2306
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2309
2025 4runner 6th gen UNDERGROUND Photos 4Runner 6th Gen (2025+) IMG_2308
After Westcott lift kit installed:
