Will all 2025 4runners w/ part-time 4wd share same axles and gear ratios?
RAB
Goose Bay
Nissan , Chev,
As the title implies ,
I'm wondering if they will have the same axels as I'm not sure if I want to get the upper trim levels as I kinda want to install some of my own trail traction aids like an ARB locker , so I dont yet see the point on the upper trim levels , along with swapping shocks andd stuff , but I am undecided as of yet .
any info is appreciated
Parker516
Parker
Old Westbury - NY
Incoming TRD OR
All the 2025 4Runners share the same axle and gear ratios, regardless of 4x2 (rear wheel drive) or 4x4 (part-time or full-time four wheel drive).
From official specs https://www.4runner6g.com/forum/thr...ance-approach-departure-breakover-angle.1295/
2025 Toyota 4runner Will all 2025 4runners w/ part-time 4wd share same axles and gear ratios? axle gear ratio transfer case ratio final drive ratio
