No moonroof / sunroof for the Trailhunter 2025 4Runner.Will a moonroof be available on 4Runner Trailhunter just as it is on Tacoma Trailhunter?
I do not see a moonroof listed here as being an option.
That’s a bummer. Thank you for the clarification.No moonroof / sunroof for the Trailhunter 2025 4Runner.
Doesn't look like 360 degree overhead PVM (Panoramic View Mode) is an option for any trim that doesn't come with it as standard.Is the 360 vỉew an option for TH? I saw it's not standard for TH from the table.
Thanks. It's a feature that I like. Lots of cars have it either as standard or options. We'll never understand Toyota's decision, I guess...Doesn't look like 360 degree overhead PVM (Panoramic View Mode) is an option for any trim that doesn't come with it as standard.
Most likely because you get the front, side and rear cameras on the off road, TRD and Trailhunter trims.Thanks. It's a feature that I like. Lots of cars have it either as standard or options. We'll never understand Toyota's decision, I guess...
Make sense. Not quite the same but close. Thanks!Most likely because you get the front, side and rear cameras on the off road, TRD and Trailhunter trims.
what do you mean? so trd and trail have cameras in the corners?Most likely because you get the front, side and rear cameras on the off road, TRD and Trailhunter trims.
Same difference I think Depending on where you grew up. Where I was raised, and or time of day when the sun is up the sunroof, and when the moon is up, it’s called the moonroof. . I grewup calling them sunroofs but some places call them moon roofs, and in the literature it’s called the moon roof from Toyota. So moonroof it is.What exactly is the difference between 'sunroof' and 'moonroof' on the 4Runner?
