Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours!
Administrator
Administrator
Administrator
Staff member
Jay
Highlander
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Rough Country's 2025 4Runner TRD Off-Road 6th gen build on:
18" Rough Country Series 78 RC Wheels (0 offset)
Rough Country M/T Mud Terrain Tires (285/65/18)
Rough Country 3.5" in lift kit
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 6
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 2
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 1
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 3
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 4
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 5
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 9
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 8
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Rough Country 3.5%22 Inch Lift Kit  0 Offset Wheels Mud Terrain Tires 10
Official Description
Rough Country's 3.5-Inch Lift Kit for the sixth-generation Toyota 4Runner TRD Offroad is engineered for adventure - whether you're conquering rocky trails, powering through muddy backwoods, or making a bold statement on the road. Elevate your ride with superior suspension, enhanced durability, and a perfectly leveled stance built for anything the trail throws your way.
Massive Ground Clearance: Gain 3.5 inches of added height to dominate rough terrain with ease. No more getting hung up on rocks or ruts - just pure off-road performance.
Perfectly Balanced Stance: Eliminates the factory rake, leveling the front with the rear for an aggressive, commanding look.
Premium Suspension Upgrades: Includes high-quality upper control arms designed to maintain optimal ball joint angles, reducing wear and tear for long-lasting performance.
Enhanced Stability & Handling: A rear track bar bracket keeps the rear axle properly centered, improving control on and off the road.
Durable & Dependable: Control arms feature rubber bushings for increased longevity and smoother suspension articulation.
Hassle-Free Installation: Designed for an easy bolt-on setup - no cutting, no drilling, just a quick and straightforward upgrade.
Get ready to push your Toyota 4Runner to new heights with Rough Country's 3.5-Inch Lift Kit - because adventure doesn't wait, and neither should you!
Fitment Notes
  • Fits TRD Offroad models ONLY.
  • Does NOT fit models equipped with Adaptive Variable Suspension (AVS).
  • Does NOT fit Trailhunter models. (Models equipped with OLD Man EMU suspension.)
  • Does NOT fit TRD PRO models. (Models equipped with TRD-tuned FOX suspension.)
Keroppi
Hawaii
Everest 2025 4Runner TRD Off-Road 6th Gen overland build by MJ Motorsports.
AFTERMARKET WHEELS, TIRES, SUSPENSION:
White Wheels: Rays Volk TE37XT 17x8.5 (+15 offset)
Mickey Thompson Baja Boss AT Tires 35x12.5R17
King Shocks 2.5" Inch Lift Kit
OTHER MODS:
Seibon Carbon Fiber Hood
Prinsu Roof Rack
CBI Offroad / Prinsu window accessory molle panel
iKamper Skycamp Roof Top Tent RTT
Baja Designs Ditch Lights Pods
TRD Pro Skid Plate
Air Dam removed
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! White Aftermarket Wheels + 35's on Everest 2025 4Runner TRD Off-Road 6th Gen Build 4
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! White Aftermarket Wheels + 35's on Everest 2025 4Runner TRD Off-Road 6th Gen Build 3
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! White Aftermarket Wheels + 35's on Everest 2025 4Runner TRD Off-Road 6th Gen Build 2
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! White Aftermarket Wheels + 35's on Everest 2025 4Runner TRD Off-Road 6th Gen Build 5
Ericd6972
Delaware
2025 TRD ORP
33" Nitto Terra Grappler tires (275/70r18) installed on 18" Factory Upgrade TRD Wheels.
So I pulled the trigger on some 275/70/18 33" Nitto Terra Grapplers tires (replaces the Falken Wildpeak AT3WA that comes with 18" TRD Wheels package upgrade). At first I wanted to go 34" with a 285/70r18 but there were not many options for the 18" wheel. Most were E load and the only nice C load I could find were the Wildpeaks but they are Heavy! 70lbs per tire.
That being said this is my wife's car, I did not want to run the E load or the heavy tire so I chose to go with a 33s and I am happy. It drives very smooth on the highway with minimal noise and I like the way it looks for now but might add a lift in the future.
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! beforewildpeaktires
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! afterwildpeaktires
Cityzen10
Ryan
Gresham OR
Mickey Thompson Baja Boss A/T
285/65/18 (33.2" Dia)
Wanted to try the wider and slightly bigger diameter Mickey's on the stock suspension and upgraded TRD 18" Wheels (+45 offset) to report if there will be any rubbing for this tire size. They fit great with no rubbing.
I'd like to maybe put some +35 or +25 offset wheels on it but I'm not in a huge hurry as they look pretty good. I think some +35 - +20 wheels will give a good poke but will rub a tiny bit without a leveling kit, lift kit, or at least pushing the front wheel well felt forward and removing the rear cover and bracket. Any of these options should do to eliminate rubbing should you choose a wheel with more poke and these wider tires.
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 20250315_154549
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 20250315_152005
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 20250315_151953
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 20250315_151913
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 20250315_151930
Lotzof4Runners
Bill
Seattle, WA
Picked her up on Friday and immediately took her for a wheel and tire swap. Managed to snap some photos before the rain started.
BF Goodrich KO3 Tires P275/70/R18
OEM TRD Pro Snowflake 18" Wheels
TRD Running Boards
No Lift
At full turn, I have some a small bit of rubbing. Might need the 1.5 level/lift kit to solve this. Still need to remove the chin. More mods coming.. More photos and video coming too. Loving this truck!
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! TRD Sport Premium - Underground - K03 Tires - P275:70:R18 - OEM TRD Pro Snowflake 18%22 Wheels
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! FONT_VIEW
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! REAR_VIEW_BLUR_PLATE
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! INTERRIOR_1
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! PEDALS
Here's a walk around.. This give you an idea of how badass the hood scoop looks (even though it's not functional) I guess I really didn't need to blur my plate if I was going to show this.
Jomckinley
Jo
Tennessee
Just got BFG KO2 285/70/17 tires put on and air dam taken off.
The tires are not rubbing, my tire guy checked as thoroughly as he could to make sure it wasn't rubbing. I'm not sure if they will start to rub, if it isn't rubbing now?
I really like the upgrades.
Update:
The ride quality is still very smooth, I can't tell much of a difference with the ride or steering.
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! bfg-ko2-tires-285-70-17-2025-4runner-sr5
TheBayT4R6Gen
san Francisco
Just got lucky while bringing my Highlander in for an oil change. The dealer really wanted hybrid highlanders so I was happy to give them the keys. No deposit, it was the only one they had and put the Tundra/Sequoia BBS wheels and KO3 tires (285/65R18)
Looks amazing and the height is nearly even with where my 5th gen with a 3” icon lift and 285/75’s stood.
Super happy with it, and love the stance, no rubbing lock to lock.
Specs:
Sequoia / Tundra TRD Pro OEM BBS Wheels (18x8")
Part number: PT960-34220-2F
+47.5mm offset / 6.5" back spacing
MSRP $1,098.98 per wheel
(but used take-off sets are available for $1500/set on Ebay and Facebook marketplace)
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Tundra Factory BBS Wheels, KO3 285:65R18 on New TRD Sport 2025 4Runner 4
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Tundra Factory BBS Wheels, KO3 285:65R18 on New TRD Sport 2025 4Runner 1
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Tundra Factory BBS Wheels, KO3 285:65R18 on New TRD Sport 2025 4Runner 2
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! Tundra Factory BBS Wheels, KO3 285:65R18 on New TRD Sport 2025 4Runner 3
KTRAN
Kevin
WA
4R
285/70/17 tires (Nitto Terra Grappler) on stock SR5 wheels on stock suspension with no lift kit. Also no rubbing.
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! -terra-grapller-tires-sr5-2025-4runner-6th-gen-
And here's another 285/70R17 installed on factory SR5 wheels and without lift:
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! grapller-tires-sr5-2025-toyota-4runner-6th-gen-
samuelvelas
sam
nyc
4runner trd sport
Put some beefy 285/60R20 Mickey Thompson Baja Boss tires on the rig. I believe it’s a hair over 33s.
No rubbing at all.
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels2
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels9
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels8
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels6
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels5
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels4
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels3
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 285:60r20 tires 2025 4runner TRD Sport factory wheels1
Update:
Just went in a trail called two towers loop in nj. No issues at all. Will definitely put westcott level kit in the future
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! img_6949-jpe
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! img_6948-jpe
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! IMG_6947
E.T.
Orlando area
2025 4Runner Off-Road
Here's a Windchill Pearl 2025 4Runner TRD Sport 6th gen with:
17" KMC Wheels (KM552 IMS)
Nitto Ridge Grappler 35/11.5/R17 tires
Lift kit (not sure which one)
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 17%22 Inch KMC Wheels KM552 IMS Nitto Ridge Grappler 35:11.5:R17 tires on lifted 2025 Toyota 4
2025 Toyota 4runner Aftermarket Wheels, OEM Upgrade Wheels and Bigger Tires on 2025+ 4Runner 6th Gen -- Add Yours! 17%22 Inch KMC Wheels KM552 IMS Nitto Ridge Grappler 35:11.5:R17 tires on lifted 2025 4Runner
samuelvelas
sam
nyc
4runner trd sport
No rubbing at all.
Update:
