Quality control issues? Can’t add rock rails and underside of 4Runner looks like a child’s art project
indy14
Utah
2025 4Runner OR
Took delivery of a 2025 4Runner TRD Off-Road yesterday. I was disappointed to learn that I would have to put a decent amount of money into it to have it live up to its “off-road” moniker. But I bit the bullet and purchased a couple of real skid plates and rock sliders, all from Toyota.
The dealer did a great job installing the skid plates and taking off the air dam. But they couldn’t install the rock sliders from Toyota. The reason? Toyota seems to have neglected to thread the holes in the frame. While the dealer showed me the lacking threads, I noticed that the underside of the 4Runner was a complete mess from some form of sealant or glue applied at the factory. Short video of what I mean:
Any thoughts or suggestions? I put a call in to Toyota and they said they would get back to me this week.
Hacksaw
az
taco
Kind of ridiculous that the dealer service department didn't have a tap and die set somewhere in the shop, so they could thread it and install it. The stuff that looks like caulking is called seam sealer. It's used to fill in any panel seams to prevent rust at the seams, and is also used for noise and vibration reduction when it seems to be applied randomly in the middle of an area. This has been in use by all automakers for a long time. Nowadays, I imagine they put the prototype vehicle in a vibration jig, scan it to find areas of higher vibration or resonance, and a computer program decides where to apply it for production vehicles. It's usually applied by robots but there may be some human-applied afterwards, during an underbody inspection at the factory. Separate from that, there may be a rubbery undercoating in places, also mainly to prevent rust, and that is sprayed on. There are youtube videos of car manufacturing processes that show these things being applied. If the thin remnant dangling threads at the end of a seam bother you, you can probably clip it with a pair of wire cutters.
indy14
Utah
2025 4Runner OR
Thanks! This is helpful. Dealership said they could do nutserts, which sounds similar to what you mentioned. But they said Toyota wouldn’t warranty it and that it wouldn’t be strong enough if the rock rails got some proper use and had to support the weight of the vehicle.
LLL1990
Toyota Camry and Ford F-150
If there should be threads for rock rails but there aren’t, what should that be labeled?
Toyota didn't install attachment points for Rock Rails.
It's hard to believe Toyota would offer a genuine Toyota Rock Rail and not make it easy to install. Did you ask the tech if the installation instructions stated that the bolts should be screwed directly into the frame? If so he should contact Toyota for guidance since the instructions are impossible to follow. Dealers have a chat line they can go to for help.
indy14
Utah
2025 4Runner OR
I think they talked to Toyota about it and I am as well. Agreed, the Toyota rock rails are supposed to be easy to mount, but that is the problem. Without the threads they won’t work. Not sure if the dealer is correct or not, but the dealer is putting this on Toyota. According to the dealer, Toyota does supply the rock rail mounting points for their own rock rails but didn’t in this case.
The strange thing is that the dealer said the SR5 trim has the mounting points, but not the TRD off-road.
