Lotzof4Runners
Bill
Seattle, WA
Picked her up on Friday and immediately took her for a wheel and tire swap. Managed to snap some photos before the rain started.
BF Goodrich KO3 Tires P275/70/R18
OEM TRD Pro Snowflake 18" Wheels
TRD Running Boards
No Lift
At full turn, I have some a small bit of rubbing. Might need the 1.5 level/lift kit to solve this. Still need to remove the chin. More mods coming.. More photos and video coming too. Loving this truck!
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift TRD Sport Premium - Underground - K03 Tires - P275:70:R18 - OEM TRD Pro Snowflake 18%22 Wheels
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift FONT_VIEW
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift REAR_VIEW_BLUR_PLATE
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift INTERRIOR_1
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift PEDALS
Here's a walk around.. This give you an idea of how badass the hood scoop looks (even though it's not functional) I guess I really didn't need to blur my plate if I was going to show this.
Gastan
Tacoma TRD Pro
First TRD Pro wheels and KO3 tires installation I've seen and it looks so good! Did you have enough miles on the factory wheels/tires to compare how the KO3s and TRD Pro wheels feels compared to stock?
Trailhunter4R
The +20 offset on the TRD Pro wheels looks perfect to me. Looks flush with the fender flares?
Lotzof4Runners
Lotzof4Runners
Bill
Seattle, WA
Thank you. I drove it maybe 30 miles from the dealer to the shop to have them swapped. The suspension is pretty tight and the ride was really stiff from the beginning. I don't feel much of a change other than it fees slightly higher (due to the inch larger tires).
Lotzof4Runners
Lotzof4Runners
Bill
Seattle, WA
They are practically flush with the center of the fender. If the tire were a 265, it would likely just just inside the fender. I went up one size. These 275s rub on full steer to the right. When it stops raining, I'm going to investigate the rubbing and see if I can kill it by trimming the fender carpet or removing the chin.
Gastan
Tacoma TRD Pro
Looks super clean. My black TRD wheels look different. Are those the Tacoma ones? Do you have a part #?
You have "TRD Wheels" which are a factory upgrade option.
The ones @Lotzof4Runners are not factory upgrade wheels but are "TRD Pro Wheels" - which are the wheels from the TRD Pro model. Here's the specs / info on these TRD Pro Wheels
TRD PRO Flat Black 18" Wheel - Toyota (PT946-35240-2F)
PART NUMBER:
PT946-35240-2F
PRICE:
$285 MSRP ($223 online)
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
+20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift 2025_Walk_Around_TRDSPORT_VIDEO_3-14-25
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift 63d8505ef99c83f14918335e439795be-jpg-
SmkyMtnTRD
Andrew
SC
‘25 4RORP, ‘16 TacoOR
I’m hoping I’ll be able to snag some TRD Pro takeoffs once they start hitting the lots. Bound to be some folks swapping to methods or black rhino wheels
Lotzof4Runners
Lotzof4Runners
Bill
Seattle, WA
These are indeed the TRD PRO wheels featured on the Tacoma and what appears to be coming on the TRD PRO 4Runner if the CAD models from the Toyota site match. @Gastan, the specs are all correct. They are on national backorder through Toyota at the moment - I was told 200 backorders by two dealers in my area.
Price is correct, but if try to order them from Elmhurst at $233 plus $450 for shipping, they will charge you and then tell you they are backordered with no date available for filling the order. The $285 is without the $30 center caps. There are some takeoffs available that are 17x9" that look very similar.
PART NUMBER:
PT946-35240-2F
PRICE:
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
+20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift {filename}
Cityzen10
Ryan
Gresham OR
She's a beauty! Congrats! the KO3's look great too. There's a video by Wescott designs where he briefly explains pushing the front fender felt forward and removing the bracket in the rear of the front fender. Might be helpful to investigate before you start trimming anything.
Henry
Henry
Southwest
Here's that Westcott video where they explain how how they fit 35's on their 2025 4Runner build
CrispyTacoLover
PART NUMBER:
PT946-35240-2F
PRICE:
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
+20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
Quick question: Are these wheels gloss or flat black? @Lotzof4Runners ?
Lotzof4Runners
Lotzof4Runners
Bill
Seattle, WA
They're listed as flat black but IMO, they're more of a satin black finish. Not glossy for sure, but not the flat black you'd see on a typical 4th Gen TRD PRO wheel. Not sure if this photo helps any.
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift WHEEL_ONLY_PT946-35240-2F
2025 Toyota 4runner TRD Sport Premium - KO3 Tires - OEM 18" TRD Pro Wheels - TRD Boards / No Lift BOX_PT946-35240-2F
