Lotzof4Runners
Bill
Seattle, WA
Nice ride! Wondering about those Nitto Terra Gapplers.
How do you like them? Have you run them in the rain?
I've got the KO3s on mine and the ride is terrible. Only other option in an 18" that is SL would be those Nittos. Had TG2's on my 2021 TRD Pro.. They were horrible, but I've heard good tings about the G3s. Any thoughts you could share? Thanks & Congrats!
Ericd6972
Ericd6972
Delaware
2025 TRD ORP
Once I put them on, my wife couldn't even tell the difference. They seem fine in the rain and they are very quiet.
AZGOLD
AH
Prescott
2025 ORP 4runner
I have found that the ride is terrible regardless of the tire. My ORP is still stock and it is the worst ride ever. The toyota branded bilstiens are dog crap for a shock. Unfortunately it will be a while until the big brands start coming out with suspension lifts. Stay away from the Wescott Designs preload collar lift too, unless you want the ride to get worse.
If you need to have a lift up front , just get a simple 2" spacer lift for the meantime until legit lift kits are available. Looking at the front struts , toyota made it so that you dont even have to remove the lower ball joint anymore to get the struts out. so, a spacer would be super easy to install
4R4Life
Sam
New Jersey
Toyota 4Runner TRD sports premium 2025
100% agree! I put KO2 on mine and it’s just horrible.. vibrates after 60m/h. Retuned back the KO2 and mount backed the stock tires.
Daronc
Daron
Santa Clarita, CA
Looks great!!
I'm looking for the same set-up and look. Can you confirm that you used the Rough Country Level Kit strut spacer and the strut shim to achieve 2" lift or just the spacer.
Ericd6972
Ericd6972
Delaware
2025 TRD ORP
Looks great!!
I used both the strut spacer and shim
