Mudguards OEM part number? Aftermarket mud flaps options?
Tennessee USA
F350
I also see two part numbers in the instructions. The last two digits, if 00, they are normal. If 10, they are wide. Might be interesting for folk with wider tires. The normal just about cover the SR5 tire spray so wider might have been a better option.
Tennessee USA
F350
The rear are a bit of a pain. You do have to drill through trim and the panel. The panel is plastic as is most of the front and back.
Drilling the holes for spring clips would be easier with wheels off or a very small 90 degree drill and short bit. Without that, you can manage it but drilling at an angle making an ugly hole.
All done, on to other stuff.
ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
Working with Rally Armor to confirm fitments for the 4Runner. Worked with them on the Land Cruiser. They are heavy enough to knock down debris and light enough to give way when you crawl over objects.
They'll be wider than OEM ones.
Any ETA yet?
Vincenzo
Southeast
I didn’t drill. I heated up a piece of coat hanger and poked it through.
ngfilla94
Nathan
St. Peters, MO
Weido97
Banned
Banned
Banned
Wei
Toyota 4runner
