dirtwheeler
United States
I just installed the Integrated Toyota Dashcam and thought I'd share some info on the install that might be useful to others.
The dashcam part number is PT949-34222 and costs $450 without installation and $615 with installation. I also saw another dealership selling it cheaper ($393.75 instead of $450), but I didn't notice this until after I purchased and installed my camera. So, it might be worth checking different dealerships if you have that option.
My local dealership had the camera in stock, so I picked it up, electing to do the installation myself rather than have their service department do it. It would be a 10 minute job if I had to do it again, but it took about a half hour because I was unsure of how much force I should apply to the light console to remove it (and needed to look for some tools). Here's how it went...
(I won't repeat the instructions in detail, because you should acquire those from Toyota, but I'll mention the additional details that I think are useful beyond the instructions).
The box does not come with installation instructions (which also includes a mounting template you will need), so ask if the parts department will print this out for you or send you a PDF that you can print out. The parts department printed out a 16-page document for me.
I opened the box and noticed there was not an SD card, but later found out it was already in the camera.
Step 1 has you disconnect the battery. I suspect this is not really needed, but I didn't want to risk frying my $450 camera, so I took the extra 10 seconds to disconnect my battery.
I skipped step 3 (applying vehicle protection). This is a pretty clean job. I assume this is for mechanics covered in grease climbing over your nice new interior.
In step 4, there are two alternate sets of instructions - one if you're a dealership and have a hard plastic mounting template, and one if you are installing yourself and cutting out a paper template (page 15). I was in the latter category. I verified the template printed at the right scale by using a metric ruler (make sure the 10 cm indicators in the printout are really 10cm long). My printout appeared to be off by about 1mm in the vertical direction, but close enough for me. I cut out the template and taped it as indicated in the instructions. Then I secured the mounting plate with it's adhesive backing.
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_133828
In step 5, the instructions will then have you remove the visor mount clips and base (that secure your sun visors). This will allow you to pull down the liner for routing cables through it. The first part just requires your fingers turning the clip counterclockwise, then pulling down. Removing the base is a little trickier since you need to be pulling down on the base while releasing two very small clips. I found that using a very small flathead screwdriver was needed for releasing the clip mounting plate. While gripping the base with needle nose pliers and pulling down, I used the small flathead screwdriver to release one clip at a time by pushing it into each clip.
Here's what it looks like with the clip removed, with the base still attached:
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_133831
Here's what it looks like with the base removed:
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_134046
Here's what the parts look like that were removed in this step:
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_134226
Step 6, removing the map light console, took me the most amount of time. I was uncomfortable at first applying a lot of force, not knowing how this would really "pop out". There are some plastic clips that take a considerable amount of force. I eventually found out that using a small pry bar worked well for this. This is the tool that I used:
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_135613
Here's what the roof map light console looks like dangling from its electronic interface:
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_135600
I just left the wire harness connected, despite the instructions. I think this is a precautionary step so it doesn't disconnect on its own, fall, and break.
The rest of the physical installation was pretty straightforward from the instructions. Here's what it looks like installed:
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_164254
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250228_164329
If you watch it long enough from the front of the vehicle, you'll see it's little red LED security light flash occasionally. But this can be disabled in the app.
My only other notes is that the Toyota Dashcam app installed OK, but I had to disable Bluetooth on my phone before I was able to get the camera to connect via WiFi. Yes, I said that correctly. What I think was happening is that the Toyota vehicle Bluetooth connection (for Android auto, etc.) would give the phone a temporary wifi to connect to. No matter how many times I told my phone to ignore the next Toyota wifi, the Bluetooth would connect and tell my phone to drop the "other" (dashcam) wifi and connect to the new temporary Toyota wifi. I did this about 6 times before I caught on and disabled Bluetooth. After that I was able to connect to the dashcam wifi and maintain a persistent connection.
By default, my camera was recording in two-minute intervals and 1080p 30 fps, but the fps can be increased to 60 if you want. It comes with a 16GB card, but you can upgrade it up to 128GB. You can download the videos via the app. Here's a screenshot from a video (this forum wouldn't let me upload the 2-minute video which is 173MB):
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 1740787517257-r0
4R Platinum or Die Trying
Central Florida
2007 4Runner Limited
I would never feel comfortable trying to do this on my own, but thank you for posting this in such detail. This is what this forum is all about....helping other 4Runner fanatics in doing such things. Great material.
tustmeimlying
Prescott
2025 4runner OR
Thanks for the write up. Do you feel the integrated dashcam is a good deal? Why did you choose it over an aftermarket Garmin or something similar? What are the main benefits of the integrated one?
Dead Horse
Oklahoma
Tundra
Those things are triple the price of a comparable Viofo/Garmin/etc.
But having it come from Toyota and be a supported thing is probably worth it to a lot of folks.
ALLLL of them with wifi that I've messed with have had some pretty mediocre apps. Middling at best. Most of them are straight trash. I have a Viofo and the wifi connection does buggy shit with either bluetooth or Android Auto...I can't remember which. I remember it being something I had to fiddle with more than I should have to get the wifi to connect and pull the video to my phone. So that might not be just a Toyota thing.
Nice writeup!
dirtwheeler
dirtwheeler
United States
Honestly, I just figure the one that Toyota chose for it would be the least hassle. I'm sure there are better and I'm sure there are cheaper. This one seems to work fine for my needs, but I just got it installed. Time will tell. FWIW, the power connection that this one uses could probably be used for any dash cam mounted in the same place, so Toyota's installation instructions could be valuable for other cams. I didn't get a multi meter out, but I would test that it's 12 volts if I decided to go that route. It would be weird if it was something else.
FWIW, I don't plan to use the video from this cam regularly. It's just there as insurance as an extra witness if I ever need it. On my Wrangler I have an action cam mounted on the front of the hood to get the hood out of the shot. I might do something similar on this 4Runner if I find I'm taking it on trails more often. It's a different use case though. Dashcam records all the time as an extra witness. Action cam is used sometimes for fun.
dirtwheeler
dirtwheeler
United States
Nice writeup!
I've got another vehicle I installed a cheap Amazon dash cam in. FWIW, I paid $172 six years ago and have never had an issue with it. But the only times I pulled video off it, I just pulled out the SD card. I'm sure there are better and cheaper options out there, but I was just going for fast and easy this go round. Ironically, I decided to install it myself because my experience with dealerships is they want my vehicle all day to do 20 minute jobs, and are running behind half the time.
run4eb
Evan
2016 4Runner SR5 TForce Special Edition
Do you feel it hindering your view in any way? Thinking about getting one of these and although I actually like the look of it, it does seem chunky. If you have any pics showing the visibility I'm sure many (me) would love to see!
dirtwheeler
dirtwheeler
United States
It's not in the line of vision and I haven't noticed it blocking my view. It's up near the rear-view mirror, so unless you're focusing on something in the sky, it's not likely to get in your way. That's just my experience so far. I'll try to get a pic of it later from a driver perspective.
Seabass
Sebastian
Connecticut
Jeep
I think that for 499 when u order the car as an installed option it’s well worth the price. U getting installed at the factory and don’t have to worry of messing up. All will click and fit where it’s suppose to. Electronics could always be a trick with functionality of the computer.. Just my thought.
dirtwheeler
dirtwheeler
United States
Unfortunately, you can't really order a Toyota 4Runner to personal spec. The dealers get an allocation and you can sometimes get one reserved (which was what happened in my case). My understanding from what others have said is that you can add some features before the vehicle has reached the port. That was not the case for mine. So, the camera was $450 without installation or $615 with installation at the dealership in my case. But the process might work differently for others. I don't know how many allocations are coming with this camera already added.
I wasn't too worried about messing it up. You just have to line up the camera mount right and they give you a template for that. Then you just route the wire and plug it in. I think where you might be in the most danger of messing something up is when you pop the light console out, but it wasn't that bad in retrospect (I was worried when I started to pull and pry on it).
I'm also not worried about the computer since the dashcam is not tied into the electronics, other than just receiving power from the vehicle's battery. You control the camera via its hard buttons (power, mic, and wifi) and an app on your phone that connects to it via wifi. So, there should be no interaction between the dashcam and any complex electronics or computers on the vehicle.
dirtwheeler
dirtwheeler
United States
I just upgraded the SD card from 16GB to 128GB. Turn off the cam before starting. You have to pull the SD card cover down then pull it out. The cover is attached to the SD card, so the SD card is removed when you pull out on the cover. You then slide the SD card to one side to remove it from the cover, and slide in the new SD card (reverse process to install new SD card back into dash cam). Turn the vehicle on and then start the dashcam. Push the wifi button, connect with the Toyota Dashcam app on your phone, then go to settings and format the new SD card. That's what I did anyway and it seems to be working fine.
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250305_145903
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250305_150624
2025 Toyota 4runner OEM Toyota Integrated Dashcam DIY install instructions write-up with photos 20250305_150555
TN Vols
TN
'19 Toyota Tacoma SR5
The OEM integrated dashcam quality seems pretty good in video footage. This video recording was posted by @jerrycaparros in his delivery thread.
Came across more video footage of the Toyota Integrated Dashcam from a 2025 4Runner
TXPanhandle
TX
2025 SR5 4x4
Do you feel like it hampers your line of sight? When I look at stoplights, etc, it blocks things.
Starting to think about removing it
LLL1990
United States
Toyota Camry and Ford F-150
Not a problem getting the dash cam where I live, Gulf States Toyota installs it as a PIO in everything they get. The hard part is getting a Toyota without one.
