Koby
B
FJC D110
congrats, looks really good. how does it impact the rear camera function?
Seabass
Sebastian
Connecticut
Jeep
Some states if you are traveling might give u hard time for having the marker plate obstructed. That is fully not visible.
TN Vols
TN
'19 Toyota Tacoma SR5
mars001
2003 4Runner SR5 4.7 V8
Looks good!
- how was it mounted to the truck?
- looks like it completely blocks the rear window. Do you have the digital rear view mirror?
ryno
ryno
sw. mo
25 4 runner
yes, rear camera is useless in stock position, im moving it up to a better location
ryno
ryno
sw. mo
25 4 runner
I need to adjust it over had a smaller tire on it with my last build. from farther back you can see all the digits fine, up close the first is blocked, no worries
ryno
ryno
sw. mo
25 4 runner
Looks good!
it mounts inn the stock hitch location, these are tow rated, so you can still hook up and tow what ever you'd like or use it for recovery
you can see over it, you maybe lose the bottom 20% of your view
mars001
So it used a single point mounting to the hitch receiver? Um... Wouldn't that make it rock left and right, as a single mounting point can never be solid.
ryno
ryno
sw. mo
25 4 runner
