Anyone else hear wind noise from the back cabin with all windows up?
Kennyg
Ken
Albuquerque, NM
2025 4-Runner TRD Sport, 2009 Matrix Sport
Right after I installed the factory roof rack cross bars, we started noticing a lot of wind noise starting about 40mph and increasing in volume the faster we went. It's so loud and freeway speeds that I'm seriously considering removing the cross bars until we need them.
Dphotos
Dale
Los Angeles
Website
www.daleberman.com
1997 Toyota 4Runner Limited
Maybe "wind noise" is too strong a term but with all windows up, and with music off, AC fan on minimum, nobody else in the vehicle, I hear something like a light blowing air noise from the back cabin. Too hard to pinpoint where, other than to say it's behind the driver position; it's kind of a broad noise.
Is this maybe coming through the speakers, as some form of noise cancelling?
Sometimes my top rack will make noise when the wind is just right.
TXPanhandle
TX
2025 SR5 4x4
I’ve thought this as well.
Dphotos
Dale
Los Angeles
Website
www.daleberman.com
It’s funny man. I thought of this post today when I was out running errands. It’s a little warmer today in NY so I had the vented seats on, as soon as I turned it off, while in motion mind you, that wind noise dissipated substantially. lol I was going to comment on this thread again tonight.
My 1997 4Runner never had ventilated seats so I can just turn it off and I would never know the difference on my new car I get in May.
zgreen
Zach
Unfortunately, it's not the vented seats. At least on the Pro, it's coming from the outside. I'm sure there will be a fix eventually!
Tennessee USA
F350
I noticed the roof rack has open holes to mount the cross bars. I wonder if they would whistle as certain speed? I think I will get some plastic push fit plugs for them just in case.
JONNYBOSCO
JOHN
SPRING HILL, FL
2025 4 RUNNER LIMITED HYBRID 4WD
Hi - do you have the cross bars installed on the roof rack? I "removed" mine and the the wind noise went away. I kept thinking I had a window cracked open..
JONNYBOSCO
JOHN
SPRING HILL, FL
I removed the cross bars and wonderd the same thing.. but its so much quiteter with them removed, the little holes (indentations) don't seem to make a difference
bird
SF Bay Area
25 TRD ORP
No such noises from my ORP other than mistaking the ventilated seats for an open window.
Depending on the type of wind noise coming from the cross bars, you might be able to mitigate it by wrapping a bungee cord around each bar. It's a common solution to fix whistling, but it's not clear that is the same issue being described here. Anyway, it might be worth a shot? Here's an example from another forum:
2025 4runner 6th gen Anyone else hear wind noise from the back cabin with all windows up? dasfasd
T24A-FTS
PNW
Hi, I have the same experience.
I own a SR5, have no roof rack, no ventilated seats and kept the original tires on, no lift. Only mod is full aluminum skid plates. I always drive with the back seat down and no issues, until recently. It’s been raining a lot lately and a couple weeks ago when backing up, I heard right away at first a sound of water coming from the trunk area, like it was stuck in a door, it really sounded from the inside, I lived with that sound for a couple days, the weird thing is that i couldn’t reproduce the sound by jerking the truck back and forth. I did my best to try and find where it was coming from with no success, around those same days on the highway I noticed in some instances like a wind noise coming from the rear, I listened closely and its almost like the sound is coming from inside, it’s so clear but distant.. of course I checked all my windows and rear window, not sure what that was but the sounds are gone now. :unsure:
DHermit
Orlando, FL
2025 4Runner Platinum
I sure hope they come up with some kind of a recall because the amount of noise that I have in my Platinum is insane. It sounds like the windows cracked in both back windows even though they're fully up. If you look at the seals you can see how poorly they are put on and they don't even seal all the way around and I assume where the Gap is is where the wind noise is coming from. No. Crossbars or any aftermarket modifications here.
