Automatic braking adjustments (Pre-Collision System PCS)?
joe
8600 Bellaire Hwy
2025 Toyota 4Runner TRD
800 miles on 2025 TRD Sport. I usually like to get off the gas and coast as long as I can prior to stopping. Going easy on the brakes I guess. However, if there is a car/object in front of me the brakes automatically apply. Seems like 5 car lengths plus when this engages. I’ve adjusted the front sensor to the max. Doesn’t seem to be a function to adjust/ override this. Any thoughts?
Rellims
Sean
ORP - Underground
Interesting, I don't think I've noticed this outside having cruise control on.
JoeYota4Runner
Joe
2014 tundra, 2025 4runner
Brakes are cheaper than an at fault rear end crash.
GoBirds
Philly
2025 4Runner TRS Sport, Honda Odyssey
It is the Pre-Collision System "PCS" feature you are experiencing. I had the same complaint. You can change sensitivity of it or turn it off via "Settings" in the dashboard.
dpg123
david
colorado
2025 4runner TRD off road
This is the answer. There was a couple interactive autos I disabled. Play around in the settings.
hammerhead
NC
2007 4runner sport, 2025 4runner
At least in my case it was Proactive Drive Assist (PDA). This was good news as it can be turned off and stay off even with restart.
3Putt
Illinois
2025 4runner SR5
Can you permanently turn it off or disable it? Now you have to turn it off every time you start the vehicle.
SouthCoast
Kingwood
2025 4runner TRD ORP
No, you have to disable it EVERY time you start the vehicle... super annoying
DHermit
Orlando, FL
2025 4Runner Platinum
If you use Carista can you make it stay off??
