kekecarioca
_CAC_
1999 4runner SR5 4x4 Manual
Is there any available information on how wide the actual Factory Wheels are?
I currently have a 2015 TRD Pro and upsized the tires to 285/70/17. The factory wheel is only 7" wide making the tires very tight at the bead. Consequently none of the standard tire shops around me can put their alignment equipment on the wheel for wheel alignments.
2025 4Runners come with some variant of 265/70/18 which (according to wheel specs on Nitto Tire) fits on a 7" wide wheel. I would be looking at the same issue if putting 285/70/18 on the 2025 18" Toyota Wheels if they turn out to only be 7" wide.
I was hoping that In the "far future" we could fit 285/70/17 with current TRD pro bronze wheels. 17" wheels seem to clear in the new Taco. I believe current TRD pro wheels have a 11mm offset.
kekecarioca
_CAC_
After seeing what a 285/17 looks like stashed underneath on the new Tacamo, I have concerns the new 4R may also have similar issues. The wheel hangs too low when mounting underneath and with bigger wheels, it's really obvious (and concerning).
Good thinking there. Time will tell and hopefully it works if one is willing to take the penalty "clearance".
olefriend
TX
Supra A90
Can we add the optional upgrade black TRD 18" wheels to the list?
Official description of 18" TRD wheels:
  • These 18-in alloy wheels with the TRD logo center cap throw down while styling up.
  • Off-road race-inspired 18x8" cast aluminum wheel with 6 lug nut pattern
  • +45 mm offset
  • $1,325 MSRP
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Widths, Brands -- 2025 4Runner 6th Gen Upgraded TRD 18%22 inch wheel (black) factory option on TRD Off-Road Premium ORP 2
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Widths, Brands -- 2025 4Runner 6th Gen Upgraded TRD 18%22 inch wheel (black) factory option on TRD Off-Road Premium ORP 1
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Widths, Brands -- 2025 4Runner 6th Gen Upgraded TRD 18%22 inch wheel factory option on TRD Off-Road Premium
gato
New England
2025 TRD Off Road
  • +45 mm offset
  • $1,325 MSRP
Upgraded TRD 18%22 inch wheel (black) factory option on TRD Off-Road Premium ORP 2.jpg
Upgraded TRD 18%22 inch wheel (black) factory option on TRD Off-Road Premium ORP 1.jpg
So these Upgraded TRD Wheels are different than the TRD Pro wheels?
Gastan
Tacoma TRD Pro
Yes, the one above is called "TRD 18" Wheels" and the TRD Pro wheels are called "TRD Pro Wheels"
TRD PRO Flat Black 18" Wheel - Toyota (PT946-35240-2F)
PART NUMBER:
PT946-35240-2F
PRICE:
$285 MSRP ($223 online)
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Widths, Brands -- 2025 4Runner 6th Gen {filename}
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Widths, Brands -- 2025 4Runner 6th Gen 63d8505ef99c83f14918335e439795be
gato
New England
2025 TRD Off Road
PART NUMBER:
PT946-35240-2F
PRICE:
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
Thank you so much for responding and confirming.
So, it makes more sense to buy 4 TRD Pro wheels to put larger tires on, then spring up for the TRD Black wheels. Also, it seems like standard ORP spare stays more tucked in under the truck. I know it is not ideal to have different diameter spare, but should get you out of the trail. Eventually I would mount a full size spare vertically inside the cargo compartment.
AZTrail
2011 4Runner Trail
Why is Toyota putting a tire on the Trail Hunter, Toyo Open Country A/T III All-Terrain 265/70R18 Load Range: SL Serv. Desc: 116T (2,756 lbs ), that has a lower load capacity and ruggedness than the tire they are putting on the Off-Road, Michelin LTX A/T 2 265/70R18 load range E Serv. Desc: 124/121R (3,527 lbs/tire)? It appears the Trail Hunter OEM tire with a SL rating (no internal reinforcement) should not even be used off-road.
Scott
2019 TRD ORP
Hi everyone,
I'm preparing to buy a 6th gen (my first new car purchase) and would like to have the dealer replace the stock wheels with one of the flat black options I see in this thread. How do I go about this?
Do I bring the dealer a part number and ask for a quote to swap the wheels? Would the upgraded wheels fit the stock tires (assuming the same diameter)? There are a number of similar wheels with different part numbers that I am trying to understand.
I'm going to keep digging into forum posts like this one, but I appreciate any input.
DangItsDen
Hayden
Yo Admins - prob worth updating the original post on this thread. The ORP comes with 265/70/18 Falken wildpeak ATs, not the Michelins listed.
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Widths, Brands -- 2025 4Runner 6th Gen IMG_7679
theo
theo
Blk4runner1960
These 2025 4Runner trim’s factory wheels are shared with the 2024 Tacoma so we know their widths, sizes, offset:
TRD Off-Road wheels width: 7.5” (18x7.5 +55mm offset)
TRD Trailhunter wheels width: 8.5” (18x8.5 +20mm offset)
TRD Pro wheels width: 8.5” (18x8.5 +20mm offset)
How wide are the 20” rim on the premier and offset
jb.aubry
JB
Quebec City
none
TRD Sport (Premium)
20" inch machine finished alloy wheels
31.5" Yokohama Geolandar A/T G015 tires (265/55R20)
As I posted in another thread, this is a weird size they selected. When you search for those dimensions 265/55R20, the options are very limited and expensive.
275/55R20 gives a larger selection and way more options for A/T tires style.
