Red_5
Anywhere
Many
It’s official!
UPDATED WITH FIRST IN-PERSON PHOTOS:
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims real-life-2025-4runner-photos-1-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims real-life-2025-4runner-photos-4-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims real-life-2025-4runner-photos-3-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims real-life-2025-4runner-photos-2-
UPDATED WITH HIGH-RES IMAGES:
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025 Toyota 4Runner Wallpapers 3 copy
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-3-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-1-copy-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-12-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-13-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-7-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-6-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-10-copy-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-2-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-8-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-11-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-5-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-4-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-toyota-4runner-wallpapers-9-
Like prior 4Runners, the new model also shares a lot with the latest Tacoma midsize pickup including the powertrains. Toyota’s increasingly ubiquitous 2.4-liter turbocharged four-cylinder will be under the hood of all sixth-generation 4Runners. The standard i-Force version delivers 278-hp and lb-ft of torque. The hybrid i-Force Max adds an electric motor and 1.87-kWh nickel-metal hydride battery for a total of 326-hp and 465 lb-ft of torque.
Towing capability grows from 5,000-lbs to 6,000-lbs.
The wheelbase of the new model has grown by 2.4-inches and overall length has grown by 4.7-inches compared to the old model. The longer overhangs mean the approach and departure angles are slightly degraded for the new 4Runner at 32 and 24 degrees respectively compared to 33 and 26 degrees for the four-wheel-drive fifth-gen. However, the nearly 20-inch shorter wheelbase compared to the Tacoma should give the 4Runner a big advantage over the pickup in breakover angle.
Both options come with the same eight-speed automatic transmission found in the Tacoma and Land Cruiser. As before, customers can choose a rear-wheel-drive, part-time four-wheel-drive or full-time four-wheel-drive system. Both 4WD systems have a two-speed transfer case and Toyota’s active traction control system to aid in sending torque to the wheels with the most grip. All variants get an automatic limited slip differential.
The TRD Off-Road, TRD Pro and the new Trailhunter version also get an electronic locking rear differential. The Platinum trim also gets a locking center differential that is optional on the Limited. New to the 4Runner is a front stabilizer bar disconnect that allows for improved articulation of the front wheels over rough terrain.
In addition to all of the usual trims found on Toyota trucks and SUVs, the 4Runner also offers the new Trailhunter trim. The Trailhunter includes ARB's Old Man Emu (OME) 2.5-inch forged shocks with remote reservoirs on the rear axle and a custom ARB roof rack. 33-inch Toyo Open Country all-terrain tires provide the grip along with two-inches of added front ground clearance and 1.5-inches in the rear.
Rock rails and high strength steel skid plates come standard on the Trailhunter along with a bronze grille and integrated 20-inch LED light bar. Toyota has also built in a 2400W inverter to power gear during overlanding adventures.
The 2025 4Runner goes on sale in fall 2024.
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims IMG_3835
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims IMG_3843
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 1712673801025-11-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 1712673832245-bg-
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims IMG_3842
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims IMG_3844
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 2025-4runner-lineu
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (9)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (4)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (1)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (2)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (5)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (7)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (8)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (10)
2025 Toyota 4runner 2025 4Runner Photos & Specs! πŸ”₯ Trailhunter, TRD Pro, Off-Road, Limited Trims 960x0 (13)
TigerEyeJazz
Miami, FL
2023 Honda HR-V Sport.
Okay this is not what I expected!! I love the side profile so much! It’s like a Sequoia shrunken with Tacoma Styling
Red_5
Anywhere
Many
Like prior 4Runners, the new model also shares a lot with the latest Tacoma midsize pickup including the powertrains. Toyota’s increasingly ubiquitous 2.4-liter turbocharged four-cylinder will be under the hood of all sixth-generation 4Runners. The standard i-Force version delivers 278-hp and lb-ft of torque. The hybrid i-Force Max adds an electric motor and 1.87-kWh nickel-metal hydride battery for a total of 326-hp and 465 lb-ft of torque. Towing capability grows from 5,000-lbs to 6,000-lbs.
Old Spice
NY
X3 currently
YES!! Looks as expected and looking great. Immediately identifiable as a 4Runner from back half, while getting the nice modern look of the new Tacoma in the front half. 🀩
Chcg12
Don
Pc0j224
2021 trd pro
Idk.. that green looks teal ..
not sure if I like the black fender cladding.. Also would like a smaller screen, but want the Trd Pro… I wonder if the larger screen will be standard on the pro?
4L!
Oklahoma
Don’t have one.
It’s official!
HIT IT OUT THE PARK
jnsplace
Eastern WA
2016 Subaru Outback 3.6R
HOLY, I LOVE IT. Love the black trims on the TRD Pro. What trim is the lighter blue? Limited?
Billet
Steve
24 4Runner TRD Pro, 23 Ram 3500 Limited Mega Cab
Interesting how the rear side window wraps up around the edge of the roof.
jnsplace
Eastern WA
I'm so glad I deposit my spot from LC to 4runner this weekend. Now to choose the trim.......going to be a hard one!
PS: love the java interior. Gimmie.
Aonarch
North GA / MT
β€˜23 Bronco OBX 2DR Lux 2.7, β€˜16 Corvette Z51
Very nice, but how does this fit with the Land Cruiser?
