The 6th gen 4Runner is made in U.S.Thanks for post OP. I was expecting to see it 7:15 PDT tonight. Looks hot. I hope it's still made in Japan.
It is on the Tacoma.Also would like a smaller screen, but want the Trd Pro… I wonder if the larger screen will be standard on the pro?
The 5th Gen T4R has a lot of rear seat room, and the new one is 5” longer. I would expect the rear seat to be quite comfortable and roomy.As expected, I love what I’m seeing. I do have a question about rear leg room of 4Runners for those with experience. Does the outgoing 4Runner have the same rear legroom as a 4 door Tacoma or do 4Runners have slightly more space for the rear seats? Currently I’m driving a 2024 Tacoma 4 door TRD Off-road for a week (rental). I love everything about it, but I’m hoping there is at least an inch or two more room in the new 4Runner for the rear Passengers. Three 6 feet tall adults in a Tacoma was a bit of a squeeze job this past weekend. Everything else is just about perfect though, and power from the new turbo 4 is more than adequate.
Taco has less. I sat in a new Taco and a 4Runner back to back at a dealership. I didn't measure, but there was a good amount more in the 4Runner.As expected, I love what I’m seeing. I do have a question about rear leg room of 4Runners for those with experience. Does the outgoing 4Runner have the same rear legroom as a 4 door Tacoma or do 4Runners have slightly more space for the rear seats? Currently I’m driving a 2024 Tacoma 4 door TRD Off-road for a week (rental). I love everything about it, but I’m hoping there is at least an inch or two more room in the new 4Runner for the rear Passengers. Three 6 feet tall adults in a Tacoma was a bit of a squeeze job this past weekend. Everything else is just about perfect though, and power from the new turbo 4 is more than adequate.
May have to go with the Limited trim to avoid the black fender cladding. Will also wager the Limited will have full-time 4WD, and with a bit of luck, power running boards.Idk.. that green looks teal ..
not sure if I like the black fender cladding.. Also would like a smaller screen, but want the Trd Pro… I wonder if the larger screen will be standard on the pro?
It it's like the Taco, the TRD-Sport should be color match also. The Off-Road kept the black ones.May have to go with the Limited trim to avoid the black fender cladding. Will also wager the Limited will have full-time 4WD, and with a bit of luck, power running boards.
Awesome. Thank you for the information. A little more room would definitely go a long way.The 5th Gen T4R has a lot of rear seat room, and the new one is 5” longer. I would expect the rear seat to be quite comfortable and roomy.
Yeah my friend sitting in the rear seat was having to do a bit of side sitting to fit behind my front passenger that is probably 6 feet 2. Even an inch or two more than the Taco will make a big difference. Thank you for the information!Taco has less. I sat in a new Taco and a 4Runner back to back at a dealership. I didn't measure, but there was a good amount more in the 4Runner.
