Scott
2019 TRD ORP
Thanks for sharing your experience with a 1up on your ORP. That'll be my set up later this week when I take delivery on a ORP.
With bikes on your rack, have you had any issues with the vehicle thinking you're in a tow mode?
After disabling the parking sensors and PKSB, are the 360 cameras affected? Do you still get all the views on the display or do some of them get disabled?
I was also concerned about the power liftgate and started another thread about that. Someone called me a sissy, but clearly they don't drive around daily with expensive bikes.
I'm planning to delete the power struts down the line. Initially, I might open my key fobs and alter the button to disable the power lift from the key. The power lift switch is also directly below the fuel door release. I'm sure the chance is extremely low for an accidental press, but it could be an expensive mistake. I'm also considering popping off the harness from that switch, but it'll probably require a bit more than that to keep things working.
Let the forums know if you end up removing the power liftgate.
I’m getting less concerned about the power liftgate, though I would still rather a normal liftgate. I think that disabling the button on the key fob and disabling the hands free mode should make it a non-issue for accidental opening. Hands free mode seems like a huge risk for accidental opening into a bike (while putting it on/off, for example)
here’s a pic of the backup camera and panoramic view. It still works pretty well, I think.
I haven’t had any issues with the car thinking I’m towing anything. I’m not familiar with any towing settings yet. Mine does have the tow package.
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups 1742824666278-eb
timelapse
ATL
2025 ORP
This is really helpful to see. I run a double super duty rack, so I tend to keep it down so it doesn't block the camera when bikes aren't loaded. I won't have the tow package installed (although I did want that for the digital rear view). From what I've read in the manual, some of the tow warnings other 6th gen users have reported are most likely due to a larger rack being tilted up and obscuring enough of the camera for Auto Trailer Detection. This is in the manual on pg 318, but you can't permanently disable it.
With your parking sensors disabled, I assume that turns them off up front as well? If I've interpreted the manual correctly, some of the tow modes let you keep front sensors, while disabling the back sensors.
I'm not in any rush to delete the power struts, but most likely will look into it once parts become available.
Scott
2019 TRD ORP
Interesting. I have a single 1up Quick Rack with an add on, but I rarely have the add on attached (usually only when I’m actually carrying a second bike)
I did attach the add on rack this weekend and found that I could have it fairly out of the way on the middle setting (45 degrees or so) and still open the liftgate, if I inserted the rack into the hitch the right amount. I’m not sure if the super duty has adjustments like the quick rack for insertion depth.
I also did drive to the trail with two bikes on my rack without any issues.
I found that if the liftgate did open with a bike on it would hit the pedal first. So I’ve considered covering the pedal with a rag or some rubber. I don’t think the force would damage the bike, but it would put some weird stress on the wheels as the liftgate pushes on the pedal.
You can also disable the power liftgate entirely in a settings menu, but then it’s very difficult to actuate.
timelapse
ATL
2025 ORP
Great suggestion regarding the 45* closed angle. I hadn't considered that. I'm also using a Kuat swing out so I don't have to remove bikes to access the back of the vehicle. This helps keep the rear hatch further away, but on my 5th gen I still can't open it with a bike on the rack (pedal hits). Of course, this swing out might further confuse the sensors now that the bikes sit further away from the vehicle. I guess I'll find out very soon.
I've only played with some 6th gen scenarios at the dealership during a test drive. I was surprised how challenging it was to close the liftgate in the "manual" setting. When I set it to manual, I couldn't get it to close on my own. A few other people tried and also struggled to get it to close all the way back down without an insane amount of force that feels like you'll break something.
Maybe the manual liftgate setting is only for opening and not closing? It was easy-ish to open without the motors. I never attempted to press the power close button while it was in manual mode. Have you tried that?
There are also settings for how far it opens (1-5, plus a user configurable one). Setting 1 barely pops it open (it wouldn't hit a bike). I guess you would then have to manually open it to full height and then auto shut still works? I wasn't able to test that workflow.
Good idea to cover the pedal on the inner most bike. Of course, just one more annoying thing to think about every ride. I doubt I'd follow through with that approach for very long. Makes me miss the simplicity of my 5th gen.
D-Money
Irvine CA
SR5 4runner
No issues with my 1Up rack! This is the last bike rack you’ll ever need, all aluminum construction and no plastic. Looks great on the new SR5, though I wish I spent the extra $50 to get a black 1UP at the time. The back up camera is definitely a little obstructed compared to my previous vehicle that had an aftermarket hitch.
Nice Yeti
Tennessee USA
F350
I have the black and I treat it with a UV protectant. No fade so far. I think the silver looks "unfinished". However, both serve the primary purpose quite well and far better that the plastic competitors.
Also looking at string, well made 2" hitch extender, if needed to clear the rear hatch. 1UP also has a swing out attachment - https://1up-usa.com/product/rakattach
ben
Ben
San Francisco
Here is ours! Kuat NV Base 2.0. This rack gets constant use (this is from a race this past weekend).
The automatic braking was obnoxious until we turned it off, and it is a little frustrating that the trunk cant be opened while the rack is on and folded up. May eventually get a small extender to avoid that issue (but the rear window helps!)
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups 5CDD00ED-E7E2-4E96-9B86-9D515287F677_1_102_o
TRD_GUY
Ken
United States
none
Picked up the Kuat NV 2.0. Super solid. Test drove with the bikes on there over a handful of speed bumps—no shaking or getting loose.
PRO TIP: If you have a REI Membership, you get 20% off on one full-priced item until 03/24. 😉
Does this rack also work for mountain bikes? 40+lbs?
timelapse
ATL
2025 ORP
I finally took delivery of my 6G and put on a Kuat swing out and 1up rack. Works fine. I selected “yes” when auto trailer detection was prompted. This lets the front parking sensors work when the rear parking sensors are disabled. If you simply disable the parking sensors yourself, Toyota doesn’t provide the ability to disable front/rear independently.
My only complaint is the annoying warning message that the PKSB is disabled and the tow mode is enabled.
Toyota should have a bike rack mode with less warnings on the dash.
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups IMG_7544
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups IMG_7576
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups IMG_7541
timelapse
ATL
2025 ORP
For anyone who is hauling bikes around daily with a power lift gate:
To prevent the risk of an accidental long button press on the key fob for the power rear door when bikes are on, I deleted that button. Used a blank insert without any contacts from Amazon. This was the most straight forward solution I could find to delete that function from the key fob without physically altering the more expensive Toyota case.
Techstream and Carista cannot disable the power lift gate button. You can only disable the panic button.
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups IMG_7517
Loudog61
Lu
Irvine California
TRD OFF ROAD PREMIUM
I have a 1UP USA single tray Rack. I can adjust how far it slides into the hitch receiver to have it just clear the back hatch in the up position. Only trouble I ran into was finding a hitch pin that was thin enough to pass through both the hitch receiver and the the part of the rack that slides into it. Wound up using the longer hitch pin by 1up but had to use foam tubing to cushion the excess length to prevent rattling. All in all, I'm happy with the set up.
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups Media (7)
2025 Toyota 4runner Bike Rack installed on 6th gen - post your setups Media (6)
