4running
TX
2020 4Runner SR5
Bolt Pattern:
6-139.7 (same as 5th gen)
Lug Nut Size:
14x1.5 (different than 5th gen's 12x1.5)
Hub Bore / Center Bore:
95.1 (different than 5th gen's 106.1)
These figures are from the 2024 Tacoma. I posted it for reference in case anyone searches up this info for aftermarket wheels, lugs studs, etc. (or for fitting 5th gen 4Runner wheels).
Since the 2024 Tacoma 4th gen and 2025 4Runner 6th gen are essentially identically mechanically. We should expect that their wheels related specs will be the same.
Old Spice
Bay Area
X3 currently
Looks like 5th gen 4Runner factory OEM wheels won't be a swap option for the 6th gen then.
Nuke
Jim
Rexburg, ID
2021 Highlander Platinum
I wonder if this will hold true for the Tacoma? However, the previous generation Taco is a lot closer to the new than the previous 4Runner is to the new generation. The new 4Runner is essentially a Tacoma with a different body, reverting back in this regard to when the 4Runner was just hatched.
TheBat
2010 4Runner Trail, 2022 GR86
Not a perfect fit but I just checked my OEM 5th gen 4Runner 17" wheels in the garage and a 14mm stud will fit no problem. You can use rings to fill the gap on the hub (assuming that they are hub centric), lots of aftermarket wheels require them, but some guys don't like them.
2014 4Runner
Bolt Pattern:
Lug Nut Size:
is this the same specs as the 3rd gen tundra?
i have a full 23 tundra set in grey that i want to use to replace the platinum gloss black wheels with.
also the new 25 4R has a 8 JJ width compared to the old 8.5/9.0 JJ spec i think
Skiddy
Seminole Florida
Method sent me the wrong lug nuts and the wrong center bore hub rings. They are sending me another set of lugs but they seem to think the rings wont be an issue since they are "lug centric" wheels.
