Administrator
Administrator
Staff member
Jay
Highlander
In case you haven't seen these specs in the full specs thread (searchable text PDF version), listing here for easy reference.
6th Gen 4Runner Towing Capacity Specs
Maximum Towing Capacity Weight: 6,000 lbs​
(per SAE J2807 Methodology)​
Fuel Capacity: 19 gallons​
Engine Oil Capacity: 5.9 qt. (with filter)​
6th Gen 4Runner Vehicle Weight by Trim Levels
  • Curb Weight (lbs):
    • Gas Engine (i-Force)
      • 2WD SR5: 4,455 lbs
      • 2WD TRD Sport: 4,610 lbs
      • 2WD Limited: 4,730 lbs
      • 4WD SR5: 4,685 lbs
      • 4WD TRD Sport: 4,850 lbs
      • 4WD TRD Off-Road: 4,850 lbs
      • 4WD Limited: 4,970 lbs
    • Hybrid Engine (i-Force Max)
      • Hybrid TRD Off-Road: 5,225 lbs
      • Hybrid Limited: 5,370 lbs
      • Hybrid Platinum: 5,390 lbs
      • Hybrid TRD Pro: 5,455 lbs
      • Hybrid Trailhunter: 5,500 lbs
  • Gross Vehicle Weight Rating (GVWR) (lbs):
      • 2WD SR5: 6,005 lbs
      • 2WD TRD Sport: 6,020 lbs
      • 2WD Limited: 6,130 lbs
      • 4WD SR5: 6,075 lbs
      • 4WD TRD Sport: 6,395 lbs
      • 4WD Off-Road: 6,240 lbs
      • 4WD Limited: 6,395 lbs
      • Hybrid TRD Off-Road: 6,505 lbs
      • Hybrid Limited: 6,505 lbs
      • Hybrid Platinum: 6,505 lbs
      • Hybrid TRD Pro: 6,505 lbs
      • Hybrid Trailhunter: 6,505 lbs
2025 Toyota 4runner Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+) Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+)
qtb007
Quentin
Hurricane, WV
23 GR Corolla
Pretty big hit to the payload on the Pro and Trailhunter, but I assume the additional armor that comes factory is at least partly to blame. Good to see that the non-hybrids are more or less the same weight as the outgoing model with a LOT more torque and gears available. Should improve drivability of the 6th gen considerably over the 5th gen.
