Getting Poor Gas Mileage
ah4rsr5
Abraham
VA
2025 4R SR5
Interesting the Toyota site also shows no start stop on the OR but it was definitely on the one I drove
I think you might be mistaking start/stop function and hybrid battery turning off the engine. Two different functions.
Start/Stop is when you completely stop the car and the engine shuts off until you press the gas pedal.
Hybrid battery can shut off the engine and run on the hybrid battery assist before engine kicks in. This can happen during a stop/redlight or coasting.
FoRunna
Atlanta, GA
I've had mine a few weeks now, haven't driven it much (weird, I know) and filled it up for the first time yesterday...18mpg on a TRD ORP Hybrid with Nitto Ridge Grappler Upgrade. Not great, and that's considering I reset the trip and MPG with a full tank at 6 miles.
I did 40 miles yesterday, averaged 23.1 on the way home driving it like an absolute sissy.
timelapse
ATL
2025 ORP
I compared the eco mode and normal mode. ECO mode is not fuel-efficient and the acceleration response is also slow. In normal mode, I drove 700 miles in the local area and the current average fuel consumption is 21.5-21.8
Super helpful. I had been using eco mode. Did 180 mile trip today in Normal mode with gravel roads and highway— jumped up to above 21 avg.
EarthPIG_0311
The 90660
'25 4Runner Limited i-Force Max, '20 Civic Si
Does the higher octane really make that much of a difference in fuel economy? I've always understood that a higher octane will not have any affect on mpg. Sounds like the hybrid is a boost in fuel economy on the low speed driving and idling. I personally would never want to waste money on more expensive fuel when it's designed for 87. One reason why the LC was out of the question for my use.
I think the slight increase in range has more to do with getting past the break in period. Don't know if octane has an impact on MPG but there is a thread out there that shows a dyno with a small bump in power with higher octane.
EarthPIG_0311
The 90660
Drove a Tacoma ORP and didn't notice the engine stopping. There are some threads on which models have it and which don't along with the spec sheet on Toyota site. That all said still seems to be some confusion on which actually do and which don't.
I believe only the gas engines have the start/stop. All Max engines do not have that function.
I am beyond happy this is the case and I don’t need to hit a button every time I get in it switch it off! Hallelujah!!!
HV engines dont get a SS button to turn it off since you have HV battery to compensate.
spyder40
Indiana
2021 4Runner ORP
Didn't look for a button and that sucks. Something about the start/stop stuff just seems like it will create a problem down the road.
FoRunna
Atlanta, GA
I've owned many vehicles with start-stop, including a 2020 X3M Comp and a Rav4 Hybrid (wife's daily) and none of them have ever had issues. Honestly, no one I've ever known has had issues with start/stop on any vehicle.
toyota's implementation of SS is actually pretty easy to use.
1. unless you press the brake pedal more than 1/3 or 1/2 or rapidly, SS will not engage.
2. if you are a person that likes to mash the brake pedal at the last second, then SS will be annoying.
3. if you gradually press the brake pedal to come to a stop then SS will never engage.
4. if you are lucky you can get a SS turn off button, but you have to press it every time you use the starter to start the engine. it will reset after each ignition off cycle.
if you use the brake pedal moderately to bring youself to a stop, a pop-up will come on in the MID screen telling you to press the brake pedal more to engage SS
so you have best of both worlds, people that like SS and those that dont and way to get around it engaging.
kobyneal
Rich
Calgary Canada
2024 Prius & 2026 4Runner
Just FYI - if you go to the equivalent Land Cruiser forum there are extensive discussions and data around this for those with the hybrid. Takes 3000-5000kms + weather + learning how to drive a hybrid to max efficiency to reach posted numbers (realize there are differences between the runner and LC but similar in enough ways to get the drift)
Orlyg1521
Orlando
portlland, OR
5th gen 4rnr
Look here's a great example of a hybrid system that actually got you 10 miles per gallon, not one or two. Ridiculous so yet I couldn't get this right. They truly dropped the ball. We're already getting 10 miles per gallon just with the gas system this hybrid would have given us another 10 that would have been a home run.https://www.motor1.com/news/760201/2026-toyota-rav4-hybrid-system/​
John2112
Austin Texas
I got 275 miles on 16 gallons of 87 gas. I will try switching to 91 now. The tires are 285/55R20 Michelin LTX AT2.
higher octane fuel generally will not increase gas mileage for a vehicle not designed to take it
Using higher octane fuel in a vehicle not designed for it will not give you better gas mileage. That's settled science.
FoRunna
Atlanta, GA
You're comparing an eco hybrid in a unibody SUV to a performance hybrid in a body-on-frame SUV. They really are two VERY different vehicles, and the hybrid systems are entirely different.
My wife has a Rav4 Hybrid, and it could not be more different in driving dynamics and implementation.
