Administrator
Administrator
Staff member
Jay
Maintenance Chart Schedule - Mileage Intervals (Oils, Fluids, Filters, Spark Plugs, Tires, Etc.) for 6th Gen 4Runner (2025+)
Key:
  • I: Inspect
  • P: Perform
  • R: Replace
  • T: Torque
Recommended Service (Thousand Mile Intervals)5101520253035404550
Add EFI Tank Additive (Island use only)PPPPPPPPPP
All Fluid LevelsIIIIIIIIII
Automatic Transmission FluidI
Automatic Transmission Fluid Cooler Hoses and ConnectionsI
Ball Joints and Dust CoversIII
Brake Lines and HosesI
Brake Linings/Drums and Brake Pads/DiscsIIIIIIIIII
Cabin Air FilterR
Drive Shaft Boots (if applicable)III
Engine Air FilterR
Engine Oil and Oil FilterRRRR
Exhaust Pipes and MountingsIII
Front Differential Oil (if applicable)III
Fuel Lines and Connections, Fuel Tank Band and Fuel Tank Vapor Vent System HosesI
Fuel Tank Cap GasketI
Installation of Driver's Floor MatIIIIIIIIII
Propeller Shaft BoltsTTT
Propeller Shaft Boots (if applicable)III
Radiator/Condenser/Intercooler (if applicable)III
Rear Differential OilIII
Rotate TiresPPPPPPPPPP
Spark PlugsR
Steering GearII
Steering Linkage and BootsIII
Transfer Case Oil (if applicable)I
Wiper BladesIIIIIIIIII
Special Operating Conditions
5101520253035404550
Ball Joints and Dust Covers(7)IIIIIII
Drive Shaft Boots (if applicable)(7)IIIIIII
Engine Air Filter(7)IIIIIIIII
Engine Oil and Oil Filter(7)RRRR
Front Differential Oil (if applicable)(8)RRR
Nuts and Bolts on Chassis and Body(7,8)TTTTTTTTTT
Propeller Shaft Bolts(7,8,10)TTTT
Propeller Shaft Boots (if applicable)(7,8,9,10)IIIIIII
Rear Differential Oil(8)RRR
Steering Linkage and Boots(7)IIIIIII
Transfer Case Oil (if applicable)(7,8)R
1 Toyota genuine fuel injector cleaner or equivalent.
2 Inspect sealed transmissions, transfer cases, and differentials for signs of leakage. If any leakage from a sealed component
is suspected, it is recommended that you have the sealed component inspected by a Toyota dealer. Inspect power steering
fluid (if equipped) and brake fluid level/condition. Inspect engine and inverter (if equipped) coolant level/condition/freezing
point. Your dealer may recommend services (Dealer-Recommended Maintenance) based on inspection results.
3 Visually inspect every 5,000 miles, and inspect thickness and disc runout every 30,000 miles.
4 Driving in certain conditions such as heavy traffic areas or urban areas or dusty areas or desert areas or dirt road may shorten
air conditioning filter's life. Therefore, it may need to be replaced earlier.
5 Replace both the engine oil and oil filter, even when the maintenance reminder does not appear, after 12 months have passed,
or when driven over 10,000 miles since the last oil change. This may cause the maintenance reminder to appear even when
driven less than 10,000 miles. Replace both engine oil and oil filter every 5,000 miles or 6 months, in which the vehicle is
mainly driven on dirt or dusty roads, when the maintenance reminder does not appear.
6 Maintenance services of spark plugs are required under the terms of the Emission Control Warranty.
7 Perform this service if you drive on dirt roads or dusty roads.
8 Perform this service if you drive while towing a trailer, using a car-top carrier, or heavy vehicle loading. Not all vehicles are
designed for towing. Refer to your Vehicle Owner’s Manual for details.
9 Operating on rough or muddy roads, or roads with melted snow.
10Including operation on roads that have road salt applied.
Recommended Service
556065707580859095100
Automatic Transmission FluidII
Automatic Transmission Fluid Cooler Hoses and ConnectionsII
Brake Lines and HosesII
Cabin Air FilterRR
Drive BeltsII
Engine Air FilterRR
Engine Coolant/Intercooler Coolant (if applicable)R
Engine Oil and Oil FilterRRRRR
Fuel Lines and Connections, Fuel Tank Band and Fuel Tank Vapor Vent System HosesII
Fuel Tank Cap GasketII
Spark PlugsR
Steering GearII
Automatic Transmission Fluid(9,10)R
Ball Joints and Dust Covers(8)IIIIIII
Drive Shaft Boots (if applicable)(8)IIIIIII
Engine Air Filter(8)IIIIIIIII
Engine Oil and Oil Filter(8)RRRRR
Front Differential Oil (if applicable)(9)RRR
Nuts and Bolts on Chassis and Body(8,9)TTTTTTTTTT
Propeller Shaft Bolts(8,9,12)TTTT
Propeller Shaft Boots (if applicable)(8,9,11,12)IIIIIII
Rear Differential Oil(9)RRR
Steering Linkage and Boots(8)IIIIIII
Transfer Case Oil (if applicable)(8,9)R
5 Initial engine/intercooler coolant (if applicable) replacement at 100,000 miles/120 months. Replace every 50,000 miles/60
months thereafter.
6 Replace both the engine oil and oil filter, even when the maintenance reminder does not appear, after 12 months have passed,
7 Maintenance services of spark plugs are required under the terms of the Emission Control Warranty.
8 Perform this service if you drive on dirt roads or dusty roads.
9 Perform this service if you drive while towing a trailer, using a car-top carrier, or heavy vehicle loading. Not all vehicles are
10Perform this service if you operate with extensive idling and/or low-speed driving for a long distance, such as police,
professional/private use like taxi or door-to-door delivery use.
11Operating on rough or muddy roads, or roads with melted snow.
12Including operation on roads that have road salt applied.
Recommended Service
105110115120125130135140145150
Ball Joints and Dust CoversIIII
Cabin Air FilterRR
Drive BeltsII
Engine Air FilterRR
Spark PlugsR
Steering GearII
Automatic Transmission Fluid(10,11)R
Ball Joints and Dust Covers(9)IIIIII
Drive Shaft Boots (if applicable)(9)IIIIII
Engine Air Filter(9)IIIIIIII
Engine Oil and Oil Filter(9)RRRRR
Front Differential Oil (if applicable)(10)RRRR
Nuts and Bolts on Chassis and Body(9,10)TTTTTTTTTT
Propeller Shaft Bolts(9,10,13)TTTTTT
Propeller Shaft Boots (if applicable)(9,10,12,13)IIIIII
Rear Differential Oil(10)RRRR
Steering Linkage and Boots(9)IIIIII
Transfer Case Oil (if applicable)(9,10)R
months thereafter.
8 Replace the vacuum pump vane and the vacuum pump vane caps with new ones and never reuse the vacuum pump vane
and the vacuum pump vane caps.
9 Perform this service if you drive on dirt roads or dusty roads.
10Perform this service if you drive while towing a trailer, using a car-top carrier, or heavy vehicle loading. Not all vehicles are
11Perform this service if you operate with extensive idling and/or low-speed driving for a long distance, such as police,
12Operating on rough or muddy roads, or roads with melted snow.
13Including operation on roads that have road salt applied.
FWTBT
Northeast
5th Gen 4Runner
Holy cow, that really is something. First oil change at 5K miles, which makes sense. But then most subsequent changes at 15K intervals, with occasional 10K intervals thrown in? Wow.
Even the Special Operating Conditions (aka severe conditions aka normal conditions for many owners) has 10k and 15K intervals, only reverting to 5K intervals at 100K miles of use. I'd like to think that these extended intervals demonstrate justified confidence in current oil and engine technologies, but really suspect this is more for environmental concerns. So owners who wish to keep their engines alive for a long time would be wise to adopt more frequent changes. I know I would.
What makes me question these charts even more is the 5K intervals for rear differential oil replacement starting at 100K miles of use in Special Operating Conditions. Every 5K miles? That can't be right?
However, if this is all accurate I do appreciate that Toyota seems to be thoughtful about what's really needed. Having some intervals at 10K and others at 15K, and shortening the intervals at higher mileage, hopefully suggests there's actual science behind this schedule.
BG1
New Jersey
2022 4R TRD Sport & 2017 Rav 4 Platinum
The US has always been used to dealers pushing 3-5K oil changes, in the days of mineral oil and no additives if was a good idea because of sludge buildup.
As oil technology improved, especially detergent acting additives, it became unnecessary, but dealers kept on pushing for it because it's profitable.
With 100% synthetic oils 10 and 15K intervals was and is common in EU where it's both a cost and ecological concern. When I came to the US many, many years ago, my identical Ford and GM engines were 10K oil changes with mineral oil. Interestingly, at that time, I couldn't purchase my similar Ford model with anti-lock brakes, whereas the EU model (Scorpio) you couldn't buy it without them.
You will not do any harm replacing the oil at shorter intervals, but there is no need. Perhaps more important is how long and what conditions you drive in daily. Short runs where the oils don't really get to normal operating temps are harmful, longer runs tend to improve the oil condition.
I remember borrowing a bosses Jaguar 4.2L - he only pottered around locally and was stunned when I gave it back after a trip of 200 miles (hard driving) he said it was entirely different and more sporty........
Your mileage may vary o_O
docboy
PNW
09 LX570
Automatic transmission fluid is lifetime under recommended services (i.e. just Inspect)?
MG-OR
Miguel
Socal
2025 4Runner TRD Off-Road (Cutting Edge)
Yup. That's why there's no transmission dipstick.
If you did ever need to change / replace the automatic transmission fluid though, here's DIY instructions for the AL80F auto transmission (gas non-hybrid models).
AZTrail
2011 4Runner Trail
The information in the above tables is different from what is in the Toyota Warranty & Maintenance Guide. One specific example is the recommended oil change intervals.
LLL1990
United States
Toyota Camry and Ford F-150
Looking through the PDF owner's manual it looks like Toyota has finally decided to use an algorithm to determine when to change the oil instead of the mileage counter they've been using. The manual shows that you will get a the usual "Maintenance Required" message for inspections and tire rotations but now there is a "Oil Maintenance" message specifically for oil changes.
Also, I change my transmission fluid every 60,000 miles and disregard that lifetime thing.
dirtwheeler
United States
I noticed this too. I downloaded a PDF from the Toyota website for my vehicle that has different info in it. I'm not going to worry about discrepancies in the original post here since I plan to refer to the info I got from Toyota for my specific vehicle (hard copy in glovebox and PDF from website).
dirtwheeler
United States
For "Special Operating Conditions" the 2025 4Runner maintenance info I received recommends replacing ATF at 60,000 miles and 120,000 miles. "Perform this service if you drive while towing a trailer, using a car-top carrier, or heavy vehicle loading" and "Perform this service if you operate with extensive idling and/or low-speed driving for a long distance, such as police, professional/private use like taxi or door-to-door delivery use". I would assume a lot of off-roading would qualify as "low-speed driving for a long distance", but I check some other boxes in this list, so I plan on the 60,000 ATF replacement too.
ah4rsr5
Abraham
VA
2025 4R SR5
Do we need to tell the dealership that we qualify under special operating conditions to get it replaced?
dirtwheeler
United States
I assume you're referring to maintenance covered under "ToyotaCare". AFAIK, ToyotaCare does not include any transmission fluid changes.
