- Thread starter
- #1
Power lift gate questions for current 6th gen Premium owners:
I have an Off-road Premium on hold to replace my 2014 5th gen. I run a 1up bike rack installed 24/7 with bikes loaded most of the time. The power lift gate creates concerns. I'm trying to figure out the best approach to prevent accidentally opening the rear door from the key fob and damaging it.
I experimented with the power lift gate settings at my local dealer with mixed results.
(1) When fully disabled, it’s insanely hard to open and close the rear door manually. How are you expected to open/close it manually when it requires so much force to override the motors? Did I miss something obvious?
(2) If I keep it enabled, it would open right into test objects and required an impact to stop. In this case, I was standing back there as if I was the bike rack. Truly surprised it doesn't take the rear parking sensor readings into account.
(3) I also tested having it only open a small amount (the setting below 1 with a little person icon next to it), but then opening and closing it manually requires too much manual torque and force.
There’s got to be a better solution. What’s everyone else doing? I'm on the verge of canceling my order if I can't figure out a practical solution for everyday use.
Maybe there's a way to disable that functionality from the key fob? Similar to how I programmed my 5th gen to open the windows from the key fob?
Thanks in advance to anyone with a 6th gen who could run some more tests or share your own experience.
