nubbins_
Okay, this is the first tank with my new 255/75/17 tires on the SR5, mostly moderate speed highway with some city and a bit of 4wd on the beach - 23.34mpg. I hand calculated based on the difference in tire sizes. I used 87 octane, mainly on normal mode, but using the the cruise control at speeds of 60-65 mph. I was at about 320 miles when I filled up, there was still about 1/4 tank left.
Sweet ride. Did you compare actual speed diff with GPS, or just factor in the theoretical size difference from 245/70R17 in your calculations?
It's been a while since I saw 255/75R17 mentioned, last time was on another midsize truck forum where it was a somewhat safer bet for clearance than 265/70R17. Looks great, might go that way instead of the usual 265
photorunner
Paul
Washington
Toyota 4Runner
I went with the measured sizes and calculated the difference in distance traveled represented as a percentage. I have run 255/75 before on a 4th gen, so I was pretty familiar with what I was getting. When I considered my biggest gripe with the 5th gen I previously owned (mileage) I recalled that the 255/75 size has a slight advantage being only 10in wide, but still worthwhile upgrade over the 30.5" diameter tires that came stock. Obviously these rigs will run 33" tires stock, so it required some self control, lol. I've got about 600 miles on the tires now and I'm very satisfied!
nubbins_
Reason why I ask is cause the 6th gen speedometer seems to be off (fast) even for people with a 265/70R18 stock size. So I wonder if SR5s are just even more egregiously inaccurate from the factory and putting 255/75R17 on pretty much dials it in properly, thus possibly making your MPG calculations close to accurate without adjustments
Skiddy
Seminole Florida
we just took a 300 mile drive on stock tires and wheels and we got 24.9 all highway miles averaging 70-75 mph
Took another 300 mile road trip after adding a 2.5" lift and upgraded 33" tires and 0 offset Method wheels and our mpg dropped to 19 all hwy
RollingRocker
Clay
Wyoming
270 mile road trip this weekend 10 miles of city driving the rest TX highways 85mph average was able to do 17.6 mpg on stock ORP
This is similar to what I am seeing with Wyoming highways speeds in to 80-85mph range. I’m also constantly battling wind as well. Put 250 miles on yesterday and fought head winds both directions. I have yet to break 20mpg.
spyder40
Indiana
2021 4Runner ORP
running 255/75/17 KO2's on my 2021 and the speedo is about spot on with the larger tires now. Unfortunately between accurate miles and heavier tires the mpg also dropped
Joey_Midnight
Nj
4runner, gt4
600 miles on the odo, stock "upgraded" wheels and tires, with chin spoiler and removed the arb roof rack. Was getting 24.8 with the roof rack and 26.1 without it going to work 50-70 mph random highways. Steady 70 is more around 23s.
2025 Toyota 4runner Real World MPG by Owners (gas non-hybrid 4Runner) - Post Yours ⛽️ 1000047611
DangItsDen
Hayden
Curious what you folks running 35's are getting for MPGs in the non hybrid... I am sitting right at 18mpg on 33" toyo at3s.
DangItsDen
Hayden
Is that with GPS mileage or just the dash/odometer?
dash/odo says 18mpg avg but fuelly which goes off of actual gas put in vs odo reading said 17.6. Is odometer off enough from the factory that GPS would be different? Tires I'm running are stock size for the ORP just with more tread (265/70/r18 toyo at3 load SL)
spyder40
Indiana
2021 4Runner ORP
Sorry, misread your post and thought you went taller tires
Kabe4
Fl
19 Rav4
428 miles. I bought it today driving it home to FL. All highway 22.4 so far
