Best value trim models for 2025 4Runner 6th gen (by use case)
Gastan
Cali
Tacoma TRD Pro
I'm curious what everyone thinks is the best value trim for each of the following use cases:
On-Road Use Only
- for me: TRD Sport
Mix of On-road & Off-road Use
- for me: TRD Off-Road
Heavy Off-Road / Overlanding Rig Use
- for me: Trailhunter
MJE
Calgary, AB
2022 Ford Bronco Sport
My use case is primarily on road. Off-road for me would be unmaintained roads you could take a Subaru down. I can agree with either of your choices in on/off road.
The TRD Sport seems to give you most of what youā€™d need & the 360 cameras are available on the premium version. What I canā€™t recall though is which trims have the 3rd row & which are hybrid. That to me might be the ultimate deciding factor. No 3rd row & hybrid for me.
But then Iā€™m probably also shopping closer to LC levels (& will compare the two) so Iā€™m probably between Limited/Platinum. Both of which might be the best choice for me, but probably arenā€™t at the top of the list when it comes to ā€˜valueā€™ trims.
DustyLens
Dusty
Phoenix,AZ
2010 4Runner SR5
I would consider only the hybrid. If you don't want the hybrid, then stick with a 5th generation. Why get a gas-only 6th generation, at least before they've been out a few years?
I mostly commute in my 4Runner (and it's a very short commute), but I like the ability to do some fairly serious off-roading here in Arizona and SoCal.
So I'm looking into a hybrid TRD Off-Road Premium, in green, with moonroof.
AlanA
Alan A
Roseville, CA
2005 Tacoma
What about the regular gas version?
retirementOwl
Steve
Miami
2023 Ford Bronco
I'd like a TRD Pro,but I won't spend $70k and I don't like losing cargo space to the battery, so....
TRD Off-Road - Problem is 2 options I want are not available
1) Sway Bar disconnect - Crazy you can't get this on a vehicle they call "Off-Road"
2) Third Row Seat- Should be available on all non-hybrids
I really want to love the new 4Runner more than I do, but without these options I'm having a hard time spending the money to trade out of my Bronco Sasquatch V6.
andim
Boston
2015 Cherokee Trailhawk
Trailhunter for light off roading and light overlanding. I could go with a TRD off road and build it up a bit. But then the price difference to the trailhunter is only ~5-7k . And since I'm not the do it yourself car mechanic type I think it's in the long run much cheaper to have the Trailhunter with all mods already done and under warranty.
I know it's a bit lame but I think there will be three types that buy a Trailhunter: People with money who just love the looks. People like me who do light off-roading and don't have the time, space, tools and skill to build up a TRD off-road. And people who plan on more serious offloading/overlanding and build up the trailhunter.
qtb007
Quentin
Hurricane, WV
23 GR Corolla, 23 4Runner Pro
While the SDM not being available on the TRD OR is surprising, a VAST majority of 4Runners don't have KDSS. I bet it is on the order of 1 in 20 or less. When I bought my '16 trail edition, I had to search far and wide to find one with KDSS. It wasn't a game changer, IMO. It drove nice on the roads but it was a heavy system and limited armor options because it hung down lower than the standard suspension.
IMO, the Sasquatch is going to be a completely different animal than a 4Runner. It is a true off road bruiser. That said, the 4Runner is pretty darn capable for what most people are doing with them and is a significantly better daily driver. If I were you, I'd jump on a Limited with 3rd row and toss an aftermarket suspension under it with some 33" all terrains and have a real jack of all trades vehicle on your hands. It won't be as good off road as the Bronco, but it will be a much better vehicle 95% of the time with a great full time 4WD system and excellent technology. And it will probably get 20% better fuel efficiency than the Bronco.
Regarding the OP's original question, I'm currently between 4Runners. I've had 3 different 5th gens ('10 SR5, '16 Trail, '23 Pro) and around 130k miles between the 3 of them. The last one was a company car, so it went back since the 2 year lease was up. I'm trying out the 4Runner-less life for the time being but watching intently to see how things play out. If I had to buy one today, I'd probably go with a TRD Off Road Premium, non-hybrid because I don't need the extra power and the extra 6 cu ft would be nice. The Pro isn't exactly in the same strata as the Pro that I had. It's moved up market considerably. I think that the 6th gen TRD OR will be a hair more capable than the 5th gen Pro while having a ton of tech that the 5th gen doesn't. After driving a bright orange 4Runner around for 2 years, I think I'm ok blending in a little bit, too.
