Administrator
Administrator
Staff member
Highlander
Here are the 7 factory wheels and tires for the 2025 4Runner 6th Gen trim levels.
Wheel Type, Material and Tire Size:
17" inch dark gray metallic alloy wheels
TRD Sport (Premium)
31.5" Yokohama Geolandar A/T G015 tires (265/55R20)
TRD Off-Road (Premium)
18" inch machine finished alloy wheels (+55mm offset)
32.6" Michelin LTX A/T 2 tires (265/70R18)
20" inch machine finished alloy wheels (+55mm offset)
20" inch black alloy wheels
18" inch flat bronze finished alloy wheels (+20mm offset)
18" inch flat black finished alloy wheels (+20mm offset)
Bolt Pattern: 6-139.7
Lug Nut Size: 14x1.5
Hub Bore / Center Bore: 95.1
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen SR5 Wheels 17%22 Inch 2025 4Runner 6th Gen
SR5 -- 18" inch dark gray metallic alloy wheels
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen TRD Sport Wheels 20%22 Inch 2025 4Runner 6th Gen
TRD Sport (Premium) -- 20" inch machine finished alloy wheels + 265/55R20 tires
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen TRD Off-Road Premium Wheels 18%22 Inch 2025 4Runner 6th Gen
TRD Off-Road (Premium) -- 18" inch machine finished alloy wheels + 265/70R18 tires
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen Limited Trim Wheels 20%22 Inch 2025 4Runner 6th Gen
Limited -- 20" machine finished alloy wheels + 265/55R20 tires
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen Platinum Wheels 20%22 Inch 2025 4Runner 6th Gen
Platinum 20" inch black alloy wheels + 265/55R20 tires
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen Trailhunter Wheels 18%22 Inch 2025 4Runner 6th Gen
Trailhunter 18-in flat bronze finished alloy wheels + 265/70R18 tires
2025 Toyota 4runner Factory Wheels & Tires (OEM) -- Offsets, Bore, Sizes, Brands -- 2025 4Runner 6th Gen TRD Pro Wheels 18%22 Inch 2025 4Runner 6th Gen
TRD Pro 18-in flat black finished alloy wheels + 265/70R18 tires
kekecarioca
_CAC_
1999 4runner SR5 4x4 Manual
Is there any info on what the offset is?
I found this on a 24' Taco forum:
" The consensus seems to be that stock TRD Offroad wheels are 7.5" wide with a +55 Offset. "
So, not sure how accurate that is but I know that the TRD PRO and Trailhunter reach the extra overall width from the wheels themselves, meaning that they have a different offset than regular TRD
qtb007
Quentin
Hurricane, WV
23 GR Corolla, 23 4Runner Pro
Pro and Trailhunter have 20mm offset wheels.
Boyds4Runner
Victor
Maryland
2015 4Runner
Is there any available information on how wide the actual Factory Wheels are?
I currently have a 2015 TRD Pro and upsized the tires to 285/70/17. The factory wheel is only 7" wide making the tires very tight at the bead. Consequently none of the standard tire shops around me can put their alignment equipment on the wheel for wheel alignments.
2025 4Runners come with some variant of 265/70/18 which (according to wheel specs on Nitto Tire) fits on a 7" wide wheel. I would be looking at the same issue if putting 285/70/18 on the 2025 18" Toyota Wheels if they turn out to only be 7" wide.
Mrknowitall
SE MI
The Toyota data sheets are notoriously buggy.
The bigger SR5 wheels go along with the bigger brakes on the 4Runner. All 4Rs get the 13.2/13.4 rotors, while Sr/SR5 Tacomas get smaller front brakes, and only Hybrid Tacos get the bigger rear brakes.
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
These 2025 4Runner trim’s factory wheels are shared with the 2024 Tacoma so we know their widths, sizes, offset:
TRD Off-Road wheels width: 7.5” (18x7.5 +55mm offset)
TRD Trailhunter wheels width: 8.5” (18x8.5 +20mm offset)
TRD Pro wheels width: 8.5” (18x8.5 +20mm offset)
Boyds4Runner
Victor
Maryland
2015 4Runner
Thank you @JenningsESQ
I should have thought to search first.
I appreciate the linked information.
looks like 285’s should not be a problem then with 18” by 8.5” width wheels.
JenningsESQ
Jon
Happy to help! You planning to fit 285's on the 2025 4Runner TRD Pro or the Trailhunter?
Boyds4Runner
Victor
Maryland
2015 4Runner
Well It depends lol.
I won't be in the market until the 2026 year. For the "wheelin" that I do the Trailhunter would be perfect. I do miss having a moon-roof though like I had on my 2004 4Runner (2015 TRD Pro moon-roof was not an option back then). If they put the moon-roof as an option on the TrailHunter by 2026 then that would be perfect. If not then the TRD-Pro it is since they are both priced the same currently.
Welp, presuming I have the money for those options too :)
Voodoo Rufus
Bakersfield, CA
2015 Subaru STI, 2007 Toyota Tacoma
From the hub numbers, it stands to reason previous generation 17" and 18" wheels would fit fine, depending on the brake system diameters.
4running
TX
2020 4Runner SR5
The 5th gen 4runner's hub bore / centerbore size was 106.1 (compared to the 6th gen 4Runner's 95.1 hub bore / center bore [spec from the new Tacoma])... so the wheels between 5th and 6th gen 4Runners won't be compatible, no?
FauxrnrLC
Charlie
Baltimore
2014 4Runner
seven inch wide wheels are fine for 285 tires, the bead gets protection from the sidewall. If you air down a lot I would then consider 9“ or 9.5” max with a 305mm or 12.5” tire
TN Vols
TN
'19 Toyota Tacoma SR5
I was looking at the 139.7x6 number. Not sure about if the hub bore matters. Maybe an adaptor if necessary?
The OEM factory 5th gen 4Runner wheels (or 3rd gen Tacoma wheels) won't be a perfect fit but a 14mm stud will fit no problem.
And then you can use hub centric rings to fill the gap difference on the hub (assuming that they're hubcentric). I'm not a fan of using hub centric rings to fill out hub bore / center bore differences, but lots of people use them.
