Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels?
TRD_GUY
Ken
none
Anyone know the offset of the wheels they have on the new TRD Pro?
2025 Toyota 4runner Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? Screenshot 2025-01-28 at 7.04.09 AM
2025 Toyota 4runner Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? Screenshot 2025-01-28 at 7.04.40 AM
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
Lotzof4Runners
Bill
Seattle, WA
I can tell you with 100% certainty that what is showing above is 18x8.5 +20mm. I've got a set of 4 and K03s sitting in my garage waiting for 6th Gen to arrive next week. Center caps are in the bottom box, so no photos of that right now. I will try to snap a photo with natural light later with the center caps in place. These are flat black but look kind of shiny due to the flash.
PT 946-35240-2F
18x8.5 TRD PRO Spoke wheel / +20mm offset / 6 bolt - 139.7mm
20 degree snap-in TPMS (must be from 25 LC/4Runner - whole new system on these models)
Toyo Open Country AT3 P265/75/R18
LINK TO TOYOTA:
https://autoparts.toyota.com/products/product/alloy-wheel-pt946352402f
These are on national backorder through Toyota. The available date is TBD.
Last check there are 200 backorders for sets of 4 according to my parts person.
2025 Toyota 4runner Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? WHEEL_ONLY
2025 Toyota 4runner Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? PT946-35240-2F
Tevo
Ohio
PT 946-35240-2F
LINK TO TOYOTA:
Just picked up the same 2024 Taco TRD Pro rims in Dayton. 2025 4Runner TRD Pro rims "not available until July" per the dealer. I am mounting 265/70/18 Toyo AT3's on Friday. Hope no issues with lugs or spacers.
Darkenergy
Wisconsin
2012 4runner, 2025 trd sport premium 4runner
I just picked up my new TRD Pro wheels today. Ordered last week. Waiting for my new black TRD Sport Premium. I wanted the optional moonroof and digital rear view mirror. I was happy to see the part number on this site. Lotzof4runners investigation on these wheels was my final decision.
4R Platinum or Die Trying
Central Florida
2007 4Runner Limited
Those wheels will look awesome on a black TRD Sport Premium! If I was going to switch from the 20" wheels to the 18" wheels, that would be my choice. Be sure to post pictures!
Lotzof4Runners
Bill
Seattle, WA
I put mine on a set of KO3s 275/70/R18 - If you got mud guards and are above 265, you may want to remove them before the tread tears them off for you :)
theo
theo
Blk4runner1960
PT 946-35240-2F
LINK TO TOYOTA:
Those rims are 8.5” or 8” wide can you post a picture with a ruler. Also the depth to clear everything up
Darkenergy
Wisconsin
I still haven't decided on tires yet. I have some of the skid plates that the pro has. Although the two front ones are polymer. Transfer case has a steel plate. Still waiting for the full length steel gas tank skid plate, as the sport premium only has a partial one. This will be my fourth new 4runner. A 87,98,2012 and now a 2025. Quite the difference over the years. First one a four cylinder and now back to a four cylinder. LOL
Darkenergy
Wisconsin
By the way the off set is +20. 5 inches from the mounting surface to the suspension side tire bead. 3.5 inch to the outer tire bead.
Tevo
Ohio
+20 offset for the 18" factory TRD Pro wheels.
Looked up the stats in wheels specs sticky:
https://www.4runner6g.com/forum/thr...-bore-sizes-brands-2025-4runner-6th-gen.1962/
Full Specs: TRD Pro OEM Wheels
18" inch flat black finished alloy wheels (+20mm offset)
Mounted the same w 265/70/18 Toyo AT3 (SL). Couldn't be happier. The Taco TRD Pro Rims have a bit more poke then 4runner TRD Pro (+20 vs. +44).
2025 Toyota 4runner Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? IMG_2428
2025 Toyota 4runner Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? IMG_2429
