KTRAN
Kevin
WA
4R
More info posted by @vready
Looks like you could get 'em for closer to $800 for the set by ordering direct from Toyota:
https://autoparts.toyotadirect.com/...dy-rear-combination-lamp-left-hand-8156135420
Saw this posted by Rave Offroad. The premium tail lights from the TRD Pro / Trailhunter / Platinum trims are a plug and play install.
Upgrade your 6th Gen 2025+ Toyota 4Runner with these OEM Premium Tail Lights, designed exclusively for the high-end trims but sadly not standard on others including the TRD Off-Road Premium. These stealthy, plug-and-play lights feature a sleek blacked-out housing and a striking geometric design with LED illuminated accent lines that infuse sophisticated, modern design cues into your ride.​
Installation is a breeze—just a few minutes with a 10mm socket, and you're ready to hit the road at a new level of swag.​
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Upgraded Tail Lights black clear version 3
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Premium tail lights are plug & play 2025 4runner 6th gen 4
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Upgraded Tail Lights black clear version 4
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Upgraded Tail Lights black clear version 2
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) Standard vs upgraded oem tail lights
DIY install video on replacing / removing / upgrading the OEM tail lights
Old Spice
Bay Area
X3 currently
Nice to know it's a simple plug & play. They look both at night and day time.
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025 4runner tail lights
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025-toyota-4runner-112-6791537b08a4e
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025_TRD_PRO_Tail_Lights_01
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025_toyota_4runner_trdpro_mudbath_038-1
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 004-2025-Toyota-4Runner-TRD-Pro-Rear-Quarter
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025-toyota-4runner-rear-glass
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 036-2025-Toyota-4Runner-TRD-Pro-rear-view
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 037-2025-Toyota-4Runner-TRD-Pro-taillight
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 004-2025-Toyota-4Runner-TRD-Pro-Rear-Quarter (1)
Tennessee USA
F350
Nice option but $$$$ are more than I expected. Plus, putting my financial hat on, if I keep adding accessories, I would get close to the cost of a higher end trim. If this was a $200-300 upgrade, maybe but $1000.
I wonder what the cost of the replacement enclosure is from Toyota Parts?
LLL1990
Toyota Camry and Ford F-150
All of the trims have full LED tail lights so they're all premium. Some of the trims have a different designs but I wouldn't consider them "premium".
zesh
Los Angeles, CA
NX 350h, MYLR
If the taillights are $1k, I can only imagine what the headlights will be.
vready
Vince
Hood River, OR
Rellims
Sean
ORP - Underground
I think a lot of people (including me) will mod to the cost over the highest trim levels.
KTRAN
Kevin
WA
4R
Sounds about right :ROFLMAO: It's the reason many of us get the lower trims, so we can enjoy the build and customizing process and pick each mod part.
KTRAN
Kevin
WA
4R
Rellims
Sean
ORP - Underground
Installed Pro/Upgraded tail lights. Did not like the red look of the stock ones and as soon as I saw these were available, despite the price, I went for it.
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) IMG_7355.JPG
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) IMG_7361.JPG
Before
2025 Toyota 4runner OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) IMG_7350.JPG
  • Like
Reactions: MJE
