KTRAN
Kevin
Bay Area CA
4R
More info posted by @vready
Looks like you could get 'em for closer to $800 for the set by ordering direct from Toyota:
https://autoparts.toyotadirect.com/...dy-rear-combination-lamp-left-hand-8156135420
Saw this posted by Rave Offroad. The premium tail lights from the TRD Pro / Trailhunter / Platinum trims are a plug and play install.
Upgrade your 6th Gen 2025+ Toyota 4Runner with these OEM Premium Tail Lights, designed exclusively for the high-end trims but sadly not standard on others including the TRD Off-Road Premium. These stealthy, plug-and-play lights feature a sleek blacked-out housing and a striking geometric design with LED illuminated accent lines that infuse sophisticated, modern design cues into your ride.
Installation is a breeze—just a few minutes with a 10mm socket, and you're ready to hit the road at a new level of swag.
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Upgraded Tail Lights black clear version 3
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Premium tail lights are plug & play 2025 4runner 6th gen 4
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Upgraded Tail Lights black clear version 4
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) OEM Upgraded Tail Lights black clear version 2
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) Standard vs upgraded oem tail lights
DIY install video on replacing / removing / upgrading the OEM tail lights
Old Spice
Bay Area
2025 4R TRD ORP
Nice to know it's a simple plug & play. They look both at night and day time.
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025 4runner tail lights
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025-toyota-4runner-112-6791537b08a4
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025_TRD_PRO_Tail_Lights_01
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025_toyota_4runner_trdpro_mudbath_038-1
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 004-2025-Toyota-4Runner-TRD-Pro-Rear-Quarter
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 2025-toyota-4runner-rear-glass
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 036-2025-Toyota-4Runner-TRD-Pro-rear-view
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 037-2025-Toyota-4Runner-TRD-Pro-taillight
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) 004-2025-Toyota-4Runner-TRD-Pro-Rear-Quarter (1)
Tennessee USA
F350
Nice option but $$$$ are more than I expected. Plus, putting my financial hat on, if I keep adding accessories, I would get close to the cost of a higher end trim. If this was a $200-300 upgrade, maybe but $1000.
I wonder what the cost of the replacement enclosure is from Toyota Parts?
LLL1990
United States
Toyota Camry and Ford F-150
All of the trims have full LED tail lights so they're all premium. Some of the trims have a different designs but I wouldn't consider them "premium".
kekecarioca
_CAC_
vready
Vince
Hood River, OR
Rellims
Sean
ORP - Underground
I think a lot of people (including me) will mod to the cost over the highest trim levels.
KTRAN
Kevin
Bay Area CA
4R
Sounds about right :ROFLMAO: It's the reason many of us get the lower trims, so we can enjoy the build and customizing process and pick each mod part.
KTRAN
Kevin
Bay Area CA
4R
Rellims
Sean
ORP - Underground
Installed Pro/Upgraded tail lights. Did not like the red look of the stock ones and as soon as I saw these were available, despite the price, I went for it.
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) IMG_7355
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) IMG_7361
Before
2025 4runner 6th gen OEM Premium / Upgraded / TRD Pro LED Taillights are plug-and-play upgrade install (clear outer lens version) IMG_7350
  • Like
Reactions: MJE
