Front brake squeal when reversing
Kokorone
Gabriel
Laguna Hills, California
2025 4Runner SR5 4WD
I’ve noted that my 4Runner lets out a long and loud brake screech when lightly braking in after reversing. Appears to happen after being parked and if you reverse in general, even after driving for quite some time.
The Tundras have a TSB for this same issue so I’m curious if Toyota will have another for this eventually.
MJE
Calgary, AB
2022 Ford Bronco Sport
I believe the LandCruiser forum had the same issue as well. I know my current car does this too, so it’s not limited to just Toyota.
Burgi
mike
NC
sr5
yup mine does the same thing. Obnoxious loud brake squealing when reversing. Only does it in reverse. I have 400 miles on my 4runner and plan to mention it at the 5k service
Kokorone
Kokorone
Gabriel
Agreed. Will be mentioning it at the first service interval.
FoozGrind
Florida
Got 210 miles on mine and when I reverse for the first time after it’s been sitting, doesn’t matter what time of day the squeal is so loud the entire neighborhood can probably hear it. It’s not normal. Taking it in for service Monday to be looked at. Bit embarrassing
mars001
2003 4Runner SR5 4.7 V8
Read that the GX 550 had the same problem that Lexus issued a recall to replace the brake pads, rotors and calipers.
dirtwheeler
Not sure if this helps, but I have never noticed my brakes squeal, so it's definitely not something that's just present in every 2025 4Runner. I would take it into the dealership and have them fix it. I wouldn't let them tell you it's "normal" either.
Kokorone
Kokorone
Gabriel
There's at least 8 people in the FB group that have the same brake squealing issue so its definitely pretty common
FoozGrind
Florida
Dealer inspecting mine today and said they can’t find anything wrong and told me everything is to spec. He did mention he has seen this issue on tundras and he still has customers waiting over 6 months for new pads but said since I came in they documented it and that’s good since there is record of my issue.
Snoopy the 4Runner
I am on the same boat. I just dropped off my truck at my local dealer. First they couldn't tell what was wrong and couldn't replicate the sound. I left it over night and they checked again in the morning. Sure enough they heard the sound and they said they would replace the rotor and the brake disc. I gotta wait another day for the parts to come in and replace those parts. Sad that I have to go through this with my new truck with less than 400 miles.
mars001
Do you know if it'll be an improved/updated set of rotor & pads? If they just replace with the same parts then it'll just come back soon or later.
