Administrator
Administrator
Staff member
Highlander
Highlighting these specs from the full specs thread:
Sport, Limited, Platinum
Off-Road
TRD Pro / Trailhutner
Approach Angle
18 degrees​
18 degrees​
19 degrees​
33 degrees​
Departure Angle
22 degrees​
22 degrees​
24 degrees​
24 degrees​
Breakover Angle
23 degrees​
24 degrees​
24 degrees​
24 degrees​
Ground Clearance
8.1 inches​
8.8 inches​
9.1 inches​
10.1 inches​
andim
Boston
2015 Cherokee Trailhawk
Is the increased ground clearance and approach angle of the TRD pro/Trailhunter because of the plastic air dam at the front of the TRD off road? If that's the only difference then that should be an easy fix.
2025 Toyota 4runner Ground Clearance, Approach Angle, Departure Angle, Breakover Angle (6th Gen 2025+ 4Runner) 1734400416398-ge
2025 Toyota 4runner Ground Clearance, Approach Angle, Departure Angle, Breakover Angle (6th Gen 2025+ 4Runner) 1734400453904-96
