Administrator
Administrator
Staff member
Highlander
Owner's Manual: 2025 4Runner 6th Gen [PDF download]
Warranty & Maintnenace Guide: 2025 4Runner 6th Gen [PDF]
Some basic maintenance specs:
Octane rating: 87 octane (Research Octane Number 91) or higher
Engine Oil Grade: 0W-20
Outside temperature
SAE 0W-20 is the best choice​
for good fuel economy and good​
starting in cold weather.​
If SAE 0W-20 is not available,​
SAE 5W-20 oil may be used.​
However, it must be replaced​
with SAE 0W-20 at the next oil​
change.​
Fuel Tank Capacity: 19.0 gal.
Wheel Nut Torque:
Steel wheel: 154 ft-lb (209 N•m, 21.3 kgf•m)
Aluminum wheel: 97 ft-lb (131 N•m, 13.4 kgf•m)
Vacuum pump replacement: 120k miles
kayasaman
Kaya
UK
Lexus IS250
Thank you :)
Ah that's interesting!
It does come with drivers position memory function... I was trying to find that one out as I couldn't see it from any of the Toyota provided promo pictures of the cabin
It's so useful and so frustrating not to have the feature... I mean who has electric seats and no memory - oh wait that would be my car :-( LOL
qtb007
Quentin
Hurricane, WV
23 GR Corolla
Technically vacuum pump is listed as inspect at 120k miles. Unclear what that inspection process is... maybe running the engine and confirming that the vacuum line is pulling at least X of negative pressure?
Hampton Roads, Virgina
Ford Mustang
Thank you :)
I have a fix for you. Set your seat to your liking and then.... don't let anyone else drive your 4Runner. Unless that is not an option.
Drizzt
Alex
Portland Oregon
Toyota Highlander
I noticed in the owners manual it states that tire chains cannot be mounted on 265/70R/18 tires. You would think that there is plenty of room for them on the rear tires.
kayasaman
Kaya
UK
Lexus IS250
Actually it's not a 4Runner I have.... it's a UK spec Lexus IS250 that barely came with electric windows. Sadly the market we have, people aren't used to more creature comforts or higher level of technology.
I actually wanted an IS350 F-Sport initially and kept showing the dealers it but IS200d (yep diesel) or IS250 was all on offer....
It's not a big deal currently as I'm the only one who drives my car unless taken to the garage for it's yearly inspection (MoT). Though if I ever had a partner and got married it would be a useful feature to have....
