Administrator
Administrator
Staff member
Jay
Highlander
Owner's Manual: 2025 4Runner 6th Gen [PDF download]
Warranty & Maintnenace Guide: 2025 4Runner 6th Gen [PDF]
Some basic maintenance specs:
Octane rating: 87 octane (Research Octane Number 91) or higher
Engine Oil Grade: 0W-20
Outside temperature​
SAE 0W-20 is the best choice​
for good fuel economy and good​
starting in cold weather.​
If SAE 0W-20 is not available,​
SAE 5W-20 oil may be used.​
However, it must be replaced​
with SAE 0W-20 at the next oil​
change.​
Fuel Tank Capacity: 19.0 gal.
Wheel Nut Torque:
Steel wheel: 154 ft-lb (209 N•m, 21.3 kgf•m)
Aluminum wheel: 97 ft-lb (131 N•m, 13.4 kgf•m)
Vacuum pump replacement: 120k miles
kayasaman
Kaya
UK
Lexus IS250
Thank you :)
Ah that's interesting!
It does come with drivers position memory function... I was trying to find that one out as I couldn't see it from any of the Toyota provided promo pictures of the cabin
It's so useful and so frustrating not to have the feature... I mean who has electric seats and no memory - oh wait that would be my car :-( LOL
qtb007
Quentin
Hurricane, WV
23 GR Corolla
Technically vacuum pump is listed as inspect at 120k miles. Unclear what that inspection process is... maybe running the engine and confirming that the vacuum line is pulling at least X of negative pressure?
ModernDay4Runner
Hampton Roads, Virgina
Ford Mustang
Thank you :)
I have a fix for you. Set your seat to your liking and then.... don't let anyone else drive your 4Runner. Unless that is not an option.
Drizzt
Alex
Portland Oregon
Toyota Highlander
I noticed in the owners manual it states that tire chains cannot be mounted on 265/70R/18 tires. You would think that there is plenty of room for them on the rear tires.
kayasaman
Kaya
UK
Lexus IS250
Actually it's not a 4Runner I have.... it's a UK spec Lexus IS250 that barely came with electric windows. Sadly the market we have, people aren't used to more creature comforts or higher level of technology.
I actually wanted an IS350 F-Sport initially and kept showing the dealers it but IS200d (yep diesel) or IS250 was all on offer....
It's not a big deal currently as I'm the only one who drives my car unless taken to the garage for it's yearly inspection (MoT). Though if I ever had a partner and got married it would be a useful feature to have....
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
Some notables features / improvements:
  • Headlight leveling dial for heavy loads/towing
  • Locking gas / fuel door
  • Light on the trailer hitch
  • Genuine Toyota lift kit up to 2.5” with 3" larger tires will still allow Toyota Safety Sense (TSS) to work.
TN Vols
TN
'19 Toyota Tacoma SR5
Saw this list of funny / interesting things from the owner's manual that @NoDak posted.
  1. they talk about the noise under the vehicle right off the bat vs previous years being buried deep in the manual. guess they got tired of all the inquiries about that noise. they even say about 5 hrs after the engine is off it happens
  2. they really go into detail about all the data collections and what is/not collected right off the bat
  3. manual headlight leveling dial
  4. trailer hitch light switch (thats new and neat)
  5. fuel door switch (i prefer manual doors for snow states)
  6. inappropriate pedal operation warning light (thats a new one)
  7. PDA indicator (lol military days flashback) (this refers to pro-active driving assist)
  8. stop light indicator warning light (This light comes on when the stop lights are illuminated by the operation of the brake pedal or the driving assist system.)
  9. there is a traction monitor display now for 4wd vehicles (shows tire direction "duh", wheel spin display "duh") i think we can figure that out already
  10. digital key looks to be standard but requires a sub and enrollment (side note, if vehicle is not operated 14+ days, digital key will not connect) (digital key will not illuminate vehicle lights when approached, power back door close & lock cannot be used)
  11. surprising there is 5 smart key sensors, drivers/passenger front door, main head unit, center console, rear storage area, rear door passenger side
  12. in 4wd models, If the shift lever is moved before the “4HI” (part time 4WD models) or “4LO” indicator turns on/off, the transfer mode may not be shifted completely. The transfer mode disengages both the front and rear driveshafts from the powertrain and allows the vehicle to move regardless of the shift position. (At this time, the indicator blinks and the buzzer sounds.) Therefore, the vehicle is free to roll even if the automatic transmission is in P
  13. surprising, you can voice command some functions, like turning the wipers to swipe once
  14. interesting aspect of the Start Stop system (A battery not designed for use with a Stop & Start system may have been installed.) which maybe perm disable the SS system ???
  15. the parking support brake function can be perm disabled in the settings menu (pita on our 23 tundra as we can only do a temp disable) (for those that know, if you open the drivers door to look out to say backup, the truck wont move due to this system)
  16. as someone has mention in another thread, you cannot switch from H4L to H4F unless you are below 62 mph, unlike 5th gen where i can switch out of H4L at any speed
  17. "S-Flow" hvac setting ( Directing airflow to the front seats only and to all seats can be switched via switch operation. Unnecessary air conditioning is suppressed, contributing to increased fuel efficiency) (can be negated if someone is sitting in the back seats)
  18. windshield washer fluid fill neck is now on the drivers side, thats going to take some time to get use to
  19. really hate the trend to move the battery so close to the firewall, pita to get out compared to being up front or trying to trickle charge during the extreme cold winters up here in ND (really easy to put the charger right on the plastic cover and cables within easy reach of the terminals now and i can keep the hood pretty much closed. this new locations is going to be a royal pita to do that now)
  20. looks like you can register the tire pressure sensor ID's yourself now per instructions in manual (not sure you could do that before)
qtb007
Quentin
Hurricane, WV
23 GR Corolla
3. love this.
5. ha, this was such a big deal when the 5th gen was released. People losing their minds about losing the lockable gas door. I prefer manual door like you.
6. is this for people that press both the gas and accelerator at the same time?
14. wouldn't count on that... a lower quality battery will probably just die more quickly
20. later 5th gen 4Runners could do this.
d2huffman
David
Olympia, WA 98513
2025 Toyota 4runner Off-Road Premium and Toyota rav4
Agree, this crazy. Must be a misprint.
