Factory OEM Tires on Delivery?
Crank1
vince
Florida
2023 Tacoma TRD
TRD Off-Road Premium on order - Looked at two Toyota sites for factory tires on delivery, one is Michelins 265/R18 another, just all terrain tires.
I am in SE district, anyone get confirmation from dealer after order, etc., placed ?
Tmurph
TJ
Nebraska
2011 Ram 2500, 2015 Dodge Charger, 2022 Nissan Sentra, 2025 4Runner TRD ORP
I don't think district matters.
From the sticky thread:
https://www.4runner6g.com/forum/thr...-bore-sizes-brands-2025-4runner-6th-gen.1962/
OEM Wheel Type, Material and Tire Size:
17" inch dark gray metallic alloy wheels
TRD Sport (Premium)
31.5" Yokohama Geolandar A/T G015 tires (265/55R20)
TRD Off-Road (Premium)
18" inch machine finished alloy wheels (+55mm offset)
32.6" Michelin LTX A/T 2 tires (265/70R18)
20" inch machine finished alloy wheels (+55mm offset)
20" inch black alloy wheels
18" inch flat bronze finished alloy wheels (+20mm offset)
18" inch flat black finished alloy wheels (+20mm offset)
Bolt Pattern: 6-139.7
Lug Nut Size: 14x1.5
Hub Bore / Center Bore: 95.1
Crank1
vince
Florida
2023 Tacoma TRD
Tyler - Thanks for the info. The last info sheet on exterior, Toyota site, did not have it listed by name.
V
CrispyTacoLover
TRD Sport (Premium)
I’m curious if the Michelin LTX AT2 is E rated.
2014 4Runner
if anyone wants my opinion, get rid of the dunlop grandtrek at20 first chance you can, garbage tires imo for up north winters.
CrispyTacoLover
They are decent road tires here in the south. Good for at least 30,000 miles.
Salukidawg
Houston, TX
2017 Toyota 4Runner
Agreed. My 5th Gen came with the Dunlops and they were fantastic tires all the way out to 60K before replacement, but I am in Texas so I don’t know how they’d perform in the Northern States in the winter.
Cityzen10
Ryan
Gresham OR
My ORP will be coming with the upgraded wheel package. Does anyone know if that package is the same as the TRD PRO and Trailhunter tires?
Qbania
Q
Victoria
2021 4Runner Limited Nightshade
I'm in the PNW, Platinum on order. 4-6 months of rain. A little shush a couple months of the year, got a good suggestion to replace the Dunlop?
KTRAN
Kevin
WA
4R
TRD Off-Road and OFF-Road Premium trims come with the same wheels no? As far as I know, there's no upgraded wheel package available.
These are all the wheels listed in the standard vs. optional trims guide:
2025 Toyota 4runner Factory OEM Tires on Delivery? factory oem wheels standard vs optional 2025 4runner 6th gen
The highlighted column is TRD Off-Road Premium trim. It comes with the same "18-in. matte-black painted and machine-finished alloy wheels with TRD center caps" as the TRD Off-Road trim. That's different than the "18-in. matte-black TRD alloy wheels" of the TRD Pro.
Here's how the factory wheels look:
2025 Toyota 4runner Factory OEM Tires on Delivery? OEM factory wheels 2025 4runner 6th gen
2025 Toyota 4runner Factory OEM Tires on Delivery? sr5-wheels-17-22-inch-2025-4runner-6th-gen-
SR5 -- 18" inch dark gray metallic alloy wheels
2025 Toyota 4runner Factory OEM Tires on Delivery? d-sport-wheels-20-22-inch-2025-4runner-6th-gen-
TRD Sport (Premium) -- 20" inch machine finished alloy wheels + 265/55R20 tires
2025 Toyota 4runner Factory OEM Tires on Delivery? premium-wheels-18-22-inch-2025-4runner-6th-gen-
TRD Off-Road (Premium) -- 18" inch machine finished alloy wheels + 265/70R18 tires
2025 Toyota 4runner Factory OEM Tires on Delivery? ed-trim-wheels-20-22-inch-2025-4runner-6th-gen-
Limited -- 20" machine finished alloy wheels + 265/55R20 tires
2025 Toyota 4runner Factory OEM Tires on Delivery? latinum-wheels-20-22-inch-2025-4runner-6th-gen-
Platinum 20" inch black alloy wheels + 265/55R20 tires
2025 Toyota 4runner Factory OEM Tires on Delivery? lhunter-wheels-18-22-inch-2025-4runner-6th-gen-
Trailhunter 18-in flat bronze finished alloy wheels + 265/70R18 tires
2025 Toyota 4runner Factory OEM Tires on Delivery? trd-pro-wheels-18-22-inch-2025-4runner-6th-gen-
Cityzen10
Ryan
Gresham OR
This is what I'm confused about. When I look at the list of package upgrades my ORP comes with, I see a wheel upgrade for $1325. When you go to the Toyota website and build a 4R this is an add on you can get and it shows a picture of all black wheel. So I'm assuming it's an upgrade to the TRD Pro wheels but there's no specifications of the tire difference.
I've seen the window sticker of some owners that have received their ORP that doesn't list this add on and they have the wheels with the machined aluminum outside ring on them. It's not the same as the photo shown of the upgrade on Toyotas website.
I'm pretty sure the upgrade will be the ALL BLACK wheels, but even the dealership has not been able to give me a definitive answer of the tires that will be on them. 🤔
I've attached my list of add ons, and a screen shot of the upgraded wheels off of Toyotas build site.
2025 Toyota 4runner Factory OEM Tires on Delivery? Screenshot_20250209_105222_Samsung Internet
2025 Toyota 4runner Factory OEM Tires on Delivery? Screenshot_20250202_070818_Samsung Internet
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
I was wonder myself and found it a few days back it was I think the Toyo wild peak atw3a I think the only you tube videos I could find were in Europe on range rovers and the sort. But that was on the press cars they drove a month ago
Rellims
Sean
ORP - Underground
This option was originally on my ORP I have reserved and as it moved through the port, it dropped off. I wanted those rims and the offset, so I'll go aftermarket. I dislike the standard ORP wheels.
