Installed Redline Hood Struts QuikLIFT kit
ryno
ryno
sw. mo
25 4 runner
It's the little things that make your life easier, and this is one of them. If you're ever under you hood or like your oil changer, these days make is it much nicer, and safer. The stock prop rod is so cheap. Of all the ways to save a dollar.
Anyways glad Redline has a great hood struts kit, super simple to install. Remove the hood bolt, install it back with the upper bracketed attached. On the body side there is already a threaded hole on the passenger side. On the driver side you use one of 4th abs module bolts to secure the lower bracket, pop on the struts and you're done. 15 minutes install.
2025 Toyota 4runner Installed Redline Hood Struts QuikLIFT kit IMG_7374
2025 Toyota 4runner Installed Redline Hood Struts QuikLIFT kit IMG_7369
2025 Toyota 4runner Installed Redline Hood Struts QuikLIFT kit IMG_7366
2014 4Runner
pros/cons for gas struts.
dont have to waste time placing a hood prop
long term they may fail and the hood falls on your head.
if you oil change yourself the gas struts are nice
me, im lucky if i open it once a quarter
